Before we get into antennas and such, I suppose, to be fair, that other HF PC based options should be mentioned;
- The now-discontinued Icom PCR100; a scaled down version of the 1000, lacks SSB capability - These next 2 are hold-onto-your-wallet priced software driven radios; the SDR1000 and the SDR14, both mentioned in some articles John Catalano wrote in MT. If you're interested in looking these 2; here are the URLs;
Flex Radio; markets the SDR1000
RFSPACE; markets the SDR14
Before I discuss the RX320, you have a little homework to do. They will save you a little grief later on...
- Assume that any cable can pick up stray RF from your PC and throw it back as noise. At the very least, coil up any loose cables (audio, USB, ect.) and tie them off with wire ties; this alone might help cut down some of the noise. Chokes and ferrite beads will be your friends
- If memory serves (my RX320 is buried in some wires at the moment), both the audio jacks (speaker and line out) are 1/8 inch mono. You will need the appropriate cable to connect to your soundcard. Make sure that you can hear something from this connection; sometimes, in some systems, the input to the soundcard is muted (check your controls in Control Panel, or in your System Tray).
- The WallWart that powers the RX320 is rather large; insure you have space for it on your power strip; or, as I'm sure many people did (I did), I have mine running off an old Astron 3Amp supply. Runs like a champ.
- The antenna connection is not a PL259 - I've forgotten what the heck that style connector (Motorola?) that is, but you will need some of those. Go to the Universal website; I'm almost positive they show the back of the RX320D. This is
important - the longer the barrel the better. There is a connection that disconnects the whip when an antenna is plugged in, but not every manufacturer's barrels are long enough to make sure that connection is tripped. It's a common complaint that new folks think the 320 is insensitive, until they realize that plug's barrel is not quite long enough to trip the whip disconnection.
- Some have found that the RS232 cable that TenTec (used to?) supply wasn't well shielded; you will need a DB9 male cable to connect to the 320.
The RX320 is a black box; it has no knobs of any kind. Software provides all the controls; and here's where the fun begins...
Go join the RX320 Yahoo group; in the 'Files' section you will find an entry called 'Controllers'. They are exactly as it is named; This is where you can find lots of third party packages that run the 320. The TenTec software that's also on that site is like a demo; it only scratches the surface of what's available on the DSP. For example, if memory serves, the TenTec software only gives you 5 filters; the 320 is capable of 32 different filters. The TenTec software will run without actually having the radio; some of the third party offerings can, too, but not all of them. Some of the hot ones you will find there include (in no particular order) RXPlus, SWLog, Clifton Turner's RX320 Controller and Scan320. There are many of them, each presenting different things the DSP can do in different orders. There are many other accessory-type packages that the 320 will handle, along with digital and other utilities as well.
Go to the SWL Broadcast Wiki and check out the user comments on EHam, as well as a fairly indepth review by Alan Johnson N4LUS written for NASWA (it can be found on the 2nd RadioIntel link, on the left of the page under the section for 'RX Reviews').
As for antennas; I'd recommend running a seperate wire, yes, just for isolation's sake. You can try the one you have now (I'm assuming from your comment that you do have one). but keep in mind that a simple wire lead in can be a conduit for noise. You might want to read up a little about antennas on the Antennas Wiki; I've heard of some cases where folks have used a coax lead in and grounded the braid seperately to good effect, but there are other options as well. In fact, there's a thread just starting out on the 320 Yahoo group on antennas now, tho I don't know how well it's going to get developed. There's also a shortwave antennas Yahoo group that might be worth investigating (that link is also on the Antennas wiki).
I'd also take a look at the
AMANDX website, as well as this very interesting page from the Boston Area DXers for more antennas ideas...
Boston Area DXers Antennas page
...both of which belong on the wiki, for sure...
73s and enjoy the new toy (I know I do- I've had one for many years, now...) Mike
