rharding64
Hello,
I have been working in making smart terminal tools for electronic test equipment, industrial gear using AT modem command scripting, and various other comm gear over the years. It is my goal to bring the comm software tools for CI-V gear to WPF/MVVM and C# windows forms world. Perhaps modular DLL code would be better. I have used something called 'PDFBOX' in c# to parse out command/syntax for test equipment remote control. As long as the PDF file syntax contains patterns within the commands it can be worked with. So my question to the group, is what source code base do developers use specifically for the PCR100/PCR1000? apparently the code base is the same for both of these hardware targets. I was thinking that using FTDI interface might be favorable replacement here along with LAN interface.
My two cents worth, my 2 dollars same thing
cheers
Ron Harding
N7HBR,
Charleroi, PA
USA
cheers
Ron Harding
N7HBR,
Charleroi, PA
USA
