PD682 Wideband Tool
gordiebill
Ontario Canada
Hello;
Would anyone have the latest wideband tool for the PD386G HT? Gigaparts sent me the tool however it is for an older version of the firmware. My firmware is vA8.01.03.005.
If you have the wideband tool for this radio, I would like to hear from you. It doesn't look like GigaParts will have the latest version anytime soon.
Thanks folks!
Gord - VA3TWT
MSS-Dave
Generally Central Florida
Hello;
Thanks folks!
Gord - VA3TWT
Do you have a PD 386 G or do you have a PD 682 like the title says? You probably mean PD362 anyways.
If GigaParts is truly partnered with Hytera they should have no problem getting that CPS Super License as it is an electronic thing that can be emailed to them. As a dealer, I have it but I cannot share it. If I sell a PD Series radio that has to be wide banded I just have to hit it before it leaves the shop then the customer can do whatever they want.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
gordiebill
Ontario Canada
Thanks for your response Dave. My mistake. It is in fact a PD 682 G model. I do have a copy of the Super License for the MD782, but it won't work on my HT.
Thanks for bringing the error to my attention. I will see if I can edit the original post.
73!
Gord - VA3TWT
MSS-Dave
73!
Gord - VA3TWT
Can you tell me what version of CPS you're using and do you have the 8.01.03.005 F/W in both? I'm playing a little bit in customer files and I'm seeing some issues to where some versions of firmware I can modify Channel spacing in other versions of where I cannot.
beischel
Pierce Township, Ohio
As mentioned in the other forum, you needed to apply the wideband tool BEFORE you upgraded the firmware. This was clearly noted in the notes provided by Gigaparts. However, they might be updating the tool to fix this issue.
