Wilson 1000/Solarcon100
Hi!
I've been a "ham Operator" for over 30+ years and been a "CB'er" since 1962. Back then, you had to "build" your rig youself from a kit (KnightKit C-11). They were tube-type rigs and could be made to increase your rf output in several ways. Nowdays, they all are surface-mount(glued on)parts, except for the output stage, which is a transistor. It's almost impossible to raise the output of a rig greater than 4½ watts and even then, it's not noticeable.
The others are right, buy the best antenna you can afford. Depending
where you want to mount the antenna would make a difference. For instance, Hustler antenna makes an solid aluminum mast about 5 feet long and you can screw on an 11 meter resonator. It has a 'stinger' that you can adjust up and down to help balance the S.W.R. You do want to get it as close to 1:1 as possible, without cutting the stinger. It can be mounted on the trailer hitch or a commercial, hevy-duty ball mount.
Another antenna for a vehicle, provided you don't have a lot of low-hanging tree limbs or over-passes. It's a 5/8ths wave, fiberglass antenna called a Solarcon 100 (I believe). It tunes from 21 mHz (15 meters to 30 mHz and is very reliable. I use one when talking 10 meter
FM. It has a low noise factor which is always good.
Now, depending on your finances and your friends finances, you all could get an AM/SSB rig and move to Channel 16 or 17 an talk all day. If you're using them to hunt or fish with, a hand-held CB
handi-talkie (Motorola has the name "Walkie-Talkie" registered, so you can't use that term.
Where was I? Sorry, I digressed. As for the coax.... Since we're talking still in the High Frequency bands, you also need to buy the very best coaxial cable that will serve the purpose. I use Belden 9913. It's 50Ω and the same size as RG-8U, but the loss is lower in the 9913 than RG-8U. The Hustler takes soldering lugs on the coax to mount it. The Solarcon will take the standard PL-259 and hear again, by the best connector.
Now, I'm not "stuck-up" as some hams are about CB'er's. As I said, I've been one since 1962 and my call sign then was 8Q3224. The F.C.C. made a mistake in issueing those types of calls, so the went to KEA1192. I'm STILL on Channel 38/ssb mode and use it to contact my adult daughter and 18 year old grandson, :wink:.
As you might have figured out, I'm a
people person and half Cajun French, LOL! I love talking to folks hearing their stories about what they've done for a living, their family and other interesting things. Spend 5 minutes with me and it will be like we've known each other, FOREVER!
GOD BLESS,
Regards (73)
Buck/KA5LQJ
