Pearl River County Sheriff Ch. 6
INDY72
Indianapolis, IN
Not sure,.. but I added all the repeaters, and Statewides are on there as well.... check em out if you get a chance. Also to anyone with a PRO-92, 2067, 96, or any of the BC's with CTCSS/CDCSS decode, if your in PRC give a listen and submit the tones for the rest of the repeaters, etc. TY in advance.
INDY72
Indianapolis, IN
I know the dispatches- North, and South, are most likely 1, and 2... and usually in MS agencies list Car to Car (155.7300) as 3, though with 7 hi band chans.... it could be different.. You should be able to get the whole line up pretty easily in a short period of time since its the holidays.. which means BUSY time for PS. I would imagine at least two TAC chans, one for each Dispatch freq,... maybe one special ops, plus the statewide, and Car to Car....... though one could be PRCDC (jail).
So eventually we will be able to list all 7 chans.
darrendotcom
Hattiesburg, MS (Oak Grove) Lamar County
Up till now I have been only monitoring the North and South dispatch channels. This was the first time I heard them mention another channel. So I will see what I can come up with. And also I have heard them occasionally simalcast on both North and South Towers.
danw5211
Mississippi
PR Towers. I have..somewhere a list of the Channels and PL tones. I'll see if I can find it. North tower has been my best bet. I use and 800mhz mobile antenna run to a wideband TV amplifier. Out of the amp I use TV grade 72 ohm coax to the scanner. works great. Stealthy and lightning proof too!
INDY72
Indianapolis, IN
Cool, PL/DPL info for the rest of the freqs, and an accurate chan listing would be great. :)
