Pennsylvania Turnpike frequency changes
n3obl
Ø
PA
Can anyone confirm if Districts 3,4,5 have switched to new setup. I presume sometime today dist 1 should flip.
pastormg2
So am I to understand correctly that the new input frequencies are also the output frequencies?
When you look it gives you the input frequency, but no output frequency.
Just wondering what it shall be so I can re-program the channels I have for PA Turnpike.
Thanks!
Mark Griffin, KB3Z
W3DMV
Gettysburg, Pa
where do you see "input" listed ? I'm looking at the
RRDB and mine shows "output or simplex" in the
frequency collun.
pastormg2
New Frequencies
If I am reading correctly these are the frequencies that are for dispatch.
Please correct me if I am incorrect.
1. 156.195 85.4 tone
2. 156.225 79.7 tone
3. 156.195 69.3 tone
4. 155.130 77.0 tone
5. 156.195 74.4 tone
Statewide 159.000 136.5 tone
HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
These changes were made a month or more ago where the inputs and outputs were swapped. The most recent database change was me deleting the remaining old listings from the transition and removing the word "new" from the frequency description for the remaining listings since it was not needed any longer to differentiate between new and old.
pastormg2
I am not hearing a thing on these new frequencies. Do I have the correct output frequency for districts statewide and 1 through 5? It's odd that at least they are transmitting a little bit.
Mark Griffin, KB3Z
HM1529
Mark Griffin, KB3Z
Which districts are you trying to hear? I can confirm that 3, 4, and 5 are all good. I can hear all three from home and while mobile.
druhe
Southwest Pa
I can also confirm that Districts 1 & 2 are good. In fact I've noted some improvement on District 1.
nosoup4u
High Bridge, NJ
I'm about 10 miles from Easton and I plugged in PTC 5 Dispatch today, it sounds HORRIBLE. It sounds like the simulcast is out of sync. The old freq always sounded pretty good.
