Pentium 3 500MHz and RSS
KD0NDO
otsego,mn
so will this work, my previous post said 50MHz.... My bad! its 500MHz
or should i find a dinosaur to program my saber.
also will this work with an AMD processor
rss version 7.01.00
WX9EMS
Lake Geneva, WI
I run a Toshiba Pentium III (Win98SE), and I would venture to guess it is around 500 Mhz. I have never had any problems with Motorola or Kenwood software on this machine. I have to slow it down when running Standard PPS software, and I can do that in the BIOS. Never have had to run MOSLO.
As far as with working with AMD, that I do not know, never had too many boxes with AMD processors.
WX9EMS
Lake Geneva, WI
I don't know anything about how your laptop is set up, or which make it is (they are all different, yet to have an identical BIOS setup screen). I go into my BIOS and change the value under "Dynamic CPU Frequency Mode" from "dynamically switchable" to "always low" and that does it for me. I do have to remember to set it back to the previous setting before booting Win98, otherwise it will not load. I also have a pause command in my autoexec.bat file which gives the opportunity to hit Ctrl C and abort the batch job and go to command prompt instead of Windows. Works amazing for RSS. As always, your mileage may vary!
WX9EMS
Lake Geneva, WI
Interesting, mine is a Portege 7200 and it does...see if you can snap a picture of your BIOS screen so I can take a look.
WX9EMS
Lake Geneva, WI
Wow, it sure isn't in there. I really can't read your BIOS version in the upper right corner, looks like 1.40 or so. I included a snapshot of my BIOS screen. Go to Toshiba's website Toshiba Support - Homepage and enter your model and such, get the BIOS upgrade and install. I would think that would be a good place to start, seems to be the only difference that I can see.
mancow
N.E. Kansas
You might try disabling the cache. I had to do that with an old PC to program X9000s.
WX9EMS
Lake Geneva, WI
Looks like you will have to run Moslo after all. Interesting that it is the same BIOS flash and the option still isn't there, but I guess that could be due to a slightly different mother board; seems to be an EU laptop. Try what mancow suggested, that might help.
