Hi all, I am getting familiarized with a new PSR-500 and digital trunked communications in general. HRO programmed the radio for me with most of the valley freqs except for the trunked Peoria PD. So I have registered here at RR and downloaded the DB for the Peoria system and talk groups. The problem is the with the reception. The transmissions are garbled most of the time. Sometimes the dispatch/field unit are both perfectly clear, sometimes just the dispatch can be heard, and sometimes the xmissions start off clear then become garbled. I thought it was perhaps a reception issue with the rubber duck antenna but even if I move outside or adjust position it is the same. At this point I am not sure if its a radio setting, or something unique about the Peoria system or what. Phoenix, MSCO and all of the other systems are working fine, but Peoria is the one I did add afterwards,
Has anyone else in the valley had problems monitoring Peoria PD? Any ideas on what I might adjust to address this?
