K2NEC
- Joined
- Oct 23, 2017
- Messages
- 2,665
They are and still will be. All they are doing is keeping unauthorized radios from using their system. You'll still be able to listen using a scanner or an sdr.
The only people this will affect are people using Motorola radios to listen.
BTW, a console can only disable a radio that has Radio Disable enabled. Chances are most people using a Motorola radio to listen haven't enabled Radio Disable.
If it's a jammer chances are they won't spend $300 on a radio then have to invest in software. They will go for the cheapest possible radio to achieve their goal. Like the guy jamming NYPD a couple of years ago. Could he have spent $200+ on a Kenwood, Icom, or Motorola? Yes But instead he bought a $25 Baofeng because it did what he needed it to. Then they would have to know how to program the radio and specifically select the radio disable. No one was using their system on analog and no one will be using their system on digital and it doesn't only effect Motorola it impacts all DMR radio's as they will not be able to receive the signal due to lack of RAS key.
