This may not be the ideal subforum for this question, but it's best place to pose it that I can think of.
My county is one of the last remaining EDACS holdouts. They are running 99 percent analog voice EDACS with about 1 percent ProVoice traffic,
and maybe a tiny bit of encrypted traffic.
The system is three separate networked simulcast systems which are interlinked.
I don't have the detailed view of system performance that the system's techs do, but from a practical viewpoint, coverage on the fringe areas is decent but it can be noisy at times. We have a substantial length of Atlantic coastline and along the coastline coverage is good for mobile radios, but not so good for portable radios. There are plenty of known dead spots. Generally, it's "abandon all hope" once you cross the dune line.
I hear a lot of noise and distortion in many transmissions. This noise and distortion, when it happens, is heard whether I'm using this radio or that radio or another radio, so I must presume that it's present in the signals received at the sites, by the subscriber units. Describing the noise, I'd say that it sounds like a sheet being ripped slowly more than anything else I can think of. That's a separate form of noise than the type of white noise which is typical of a transmission with a poor S/N ratio which is usually from a portable radio at the fringe of coverage.
I'm even hearing noise in the background when dispatchers are talking, and I presume they're using non-RF voice paths into the system, be it leased lines or VOIP, or whatever...I don't really know, and certainly in the case of the Sheriff's Department this is true. And it changes from transmission to transmission. Some are clean. The next may have a ripping sheet in the background.
What is that ripping sheet distortion? Simulcast distortion? I'd like to hear an example of what that is supposed to sound like.
In general, if I were the system administrator, I'd want an effort to be made to try to improve portable coverage.
I'd also think that they have noise problems that need to be addressed NOW.
At some point, this system is due to switch over to P25 and as I have last heard, it's going directly to Phase II with no stop at Phase I first.
I think that's a pretty bold move. I understand the cost savings in not having to touch every system radio AGAIN but it also seems to me that
there's a benefit to taking it one step at a time.
When they do switch over to Phase II, I have to be realistic and expect the radio techs to be very busy addressing a LOT of problems.
But what I'm getting at, the question I'm taking too long to ask, is, given the description of current system performance, how do you think that the
system will perform after switchover? Are the fringe coverage cases going to get better or worse?
As I'm listening now, I can listen on two simulcast systems. One gives me an RSSI indication of about -103 dBM and the others, about -97. As per the RSSI indicator on my Harris XL-185 portable radio.
