Personal Role Radio - PRC-343
trooperdude
SFO Bay Area and Las Vegas NV
http://www.milspec.ca/radspec/prc-343.html
Links back to a Canadian website, but I wonder if other NATO forces use this ?
AN/PRC-343
AN/PRC-343 (H4855) PRR
Return to IndexAN/PRC-343 (H4855)
The AN/PRC-343 (NSN 5820-99-721-8335) Personal Role Radio (PRR) is a compact and lightweight short-range communication transceiver set. This radio set utilizes advanced wireless LAN technology, incorporating spread spectrum techniques at 2.4 GHz, ensuring that the system has a low probability of interception and detection and is designed to perform in dense electromagnetic environment. The radio transmissions utilize a proprietary form of Direct Sequence Spread Spectrum which, to an eavesdropper, will appear like noise.
The H4855 has been designed as a highly integrated package minimizing interconnecting cables and providing for the simplest possible user interface. The PRR has only two controls - On/Off/Volume switch and a smaller channel selector, switching between 16 preset channels.
Multiple variants of the Push-to-Talk (PTT) switch assembly are available for single or dual radio operation or for interfacing to various sensors. A situational awareness and reporting system which interfaces with the H4855 reports essential information from every team member. Each unit is provided with a specific group, selected from a total of 256 available channels.
The PRR can transmit voice and data (38.4 Kbps) simultaneously. Data from external sensors or sensors on the body (e.g. for gas alarm) can be transmitted as tone or as digital voice.
The headset is both rugged and flexible and compatible with all standard military headgear.
The system supports both broadcast, commander to troops or a private conversation between two units.
The PTT switch is mated to the radio body by use of a single fixing. The dual role control switch has two pressel switches, one for PRR and one for CNR. The hands-free PTT uses a wireless coded scheme that ensures only one radio will be operated by the PTT. Re-coding a PTT to operate a radio can be accomplished in the field by the end user. The hands-free PTT operates at 435 MHz and is uniquely coded to operate the PRR from a few meters.
The complete PRR system can be assembled by the user or technical staff for the selected role. The role will be either single use, where the only radio system to be utilized is the PRR, or dual user, for which the user can also operate a combat radio (CNR).
A relay unit consists of two linked PRR in a saddle bag. They can be dropped to a suitable place to extend the range. The PRR comes in different colors for different usages; there also is a watertight bag (equipment is submersible to 8 meters /25 feet).
The US Marine Corps uses the expression Integrated Intra Squad Radio (IISR) to describe the role of a PRR.
Features:
2.4 GHz Spread Spectrum
Low probability of Interception
Low probability of Detection
Up to 500m Range
Rugged headset proven in field service
Compatibility with all military clothing and protective hedger
Simple user interface
256 Channel capability (16 directly available to the user)
Hands-free wireless PTT
Easily mounted on the user- small and unobtrusive
Operates in a wide range of military scenarios
Operates independently of any infrastructures
Operates from 2 standard AA size batteries
Specifications:
Frequency Coverage: 2,400 - 2483 MHz, 256 Channels available
Modulation: QPSK (Direct Sequence Spread Spectrum)
Voice Coding: CVSD
Data Protocol: Modified IEEE 802.11
RF Power Output: 100 mW
Range: 500 meters (Rural Terrain) transmission through up to three floors (Urban Terrain)
Power Requirements: 2 AA primary cells provide typically 24 hour use (1:7:16 Tx/Rx/S’BY Ratio)
Weighs: 1.5 kg
Microphone: Electret Noise Canceling
Respirator: NBC Compatible
Ear Piece: Custom Molded design
Compatibility: VHF Combat Radio, UHF Combat Radio, HF Combat Radio
Hands-Free Operation: 435 MHz wireless operation
128 Bit Unique Coding
Simple Code Learn Mode
Accessories:
OD or sand colour
Various headsets
Various Single and Dual Push to Talk Assemblies
Replacement Antenna
Remote Push-to-Talk Button
Occasional swimmers' kit
Personal Role Radio Vehicle Intercom System (PRR VIS)
Publications:
5820-F-500-211 Operator's Guide
NSN:
PRC-343 / PRR H4855: 5820-99-721-8335
Single PTT: 5820-99-739-4033
Dual PTT (7 Pin CNR): 5820-99-127-2911
Remote PTT: 5820-99-342-4097
Headset: 5965-99-280-7276
Manufacturer:
Marconi Selex Communications
b7spectra
EMS Dispatcher
Cobb County, GA
500 meter range on it isn't much, unless they are going to be in an area where they can connect to a LAN. Guess they are good for short range.
LEH
Yorktown, Virginia
and weighing in at over three pounds (1.5 kilo * 2.2 lbs/kg), it is not a a light weight either. A PSR -500 with batteries is just over a pound (~.8 kg)
Up to 500 meters (~1600 feet) for 2.4 ghz isn't too bad for 100 mw.
The specialized connectivity would (i.e., headset and such) would be a drawback (IMHO).
