Peterborough Fire DMR update
Jradioptbo
Peterborough, Ontario
Peterborough Fire has fully switched all radios to DMR.
Peterborough Fire OPS1 154.250 is DMR (no longer analog) .
Sounds much better and a stronger signal.Fire calls are being dispatched through OPS1 and OPS2 from Peterborough Control on Sherbrooke Street.
If OPS1 has a fire call currently in progress, and another call is dispatched , all those units are assigned to OPS2
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Did you happen to notice the Colour Code and talkgroup they use on OPS1?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I was there earlier in the week and was surprised they were still analog. Guess I missed the cutover by a few days.
Jradioptbo
I had the scanner programmed as analog conventional at the time with AUTO modulation so it displayed DMR and played the digital audio when they switched over friday , and it came through clear with good speech audio. I will have to reprogram it as a ONE-TRUNK on MODE2 and then i will submit that info to the database once i get the CC and TG.
VA3DBJ
Ontario Database Admin
There are using the same colour and RID's as Repeater 2/CH 2. Database has been updated. :)
But I have noticed that the power or the antenna alignment is different as the signal is coming in weaker for me, compared to the old analog repeater.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I suspect this is an IPSC system. The constant data bursts on 154.250 and 153.320 would seem to confirm it.
I caught a call earlier today that seemed to be repeated on both these frequencies.
Jradioptbo
I am still hearing paging tones and then the normal call on OPS1. Is it normal to have paging tones on DMR? This is also on both frequencies.
I also wonder because of the sites . The power reduced on 154.250 that some are reporting. The coverage area for each of the towers on both frequencies.
Also, Mike before the switchover, I was hearing those data bursts on 163.140.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Yes, many agencies use two tone over DMR.
It looks to me like 154.250, 163.140 and 153.320 form a 3 site IPSC system. All 3 repeaters have a cc of 5 and ask were carrying group 103 on slot 1. The conventional channels in the database can probably be removed and a linked conventional system created in their place once confirmed.
