PGE New System 2018
jeremym70
Washington State
Anyone still tracking this system?
Seems like PGE has started using this system in the last few weeks as I am actually seeing individual radio ID’s from the dispatchers and crews on the four main dispatch channels, rather than everyone showing up as ID 1.
Still no luck with the 996P2 or 325P2 tracking it, the SDS seems to mostly track it but still misses some transmissions.
Checked for the Welches and Dunn’s Corner sites, but neither are live yet. Brightwood and maybe Timberline are up.
kd7jfv
Bend, Oregon
I received the following submission but I'm not able to complete it without site ID numbers. Can someone get site ID's for the following?
Add new sites:
Eagle Crest:
217.043750 LCN 4 Color Code 0
217.168750 LCN 14 Color Code 0
217.293750 LCN 24 Color Code 0
217.418750 LCN 34 Color Code 0
Lat: 44.984560
Long: -123.142900
Range: 25 Miles
Unknown:
217.018750 LCN 2 Color Code 0
217.143750 LCN 12 Color Code 0
217.268750 LCN 22 Color Code 0
217.393750 LCN 32 Color Code 0
OregonScanner
Sherwood, Oregon, USA
I made that submission.
I'm getting this site from Sherwood but I'm not sure where the site is yet:
cinsu
Somewhere between FOE, PDX, YVR or SYD
I'll add a little bit to the story. Last week I took a drive down to Salem (ok I rode, wife drove) and watched 217 on SDRSharp. I picked up the same 217.01875 control channel identified as site 3.2. I could pick it up from the 5/205 split all the way into Salem. They're either doing some sort of simulcast or it isn't round butte. Maybe Timberline? That would be the only thing I could think of that could be received from Salem to Portland to Terrebonne where Duane is.
jeremym70
Washington State
I picked up site 3.2 from Gresham and heard it east up 26 all the way past Rhododendron. 217.01875 control channel.
So my bet is Timberline as well.
jeb2942
Hillsboro, Oregon
You're probably right on Timberline as I can pick up the site weakly from Hillsboro and I don't believe I should be hearing Round Butte from here.
The Eagle Crest site I cannot hear from here.
cinsu
Are you sure its Site 3.5 as Region 3 appears to be Jefferson County. The coordinates given are for Eagle Crest in Polk County. Just checking before I put it in the database.
Thanks!
Yes, I was receiving that one while in Salem as well. The regions haven’t made much sense yet.
jeb2942
Hillsboro, Oregon
Thanks!
Yes,,, Site L1-3.5; CC=9 217.04375
The signal level is very strong in Yamhill Co while I was in the Newberg area.
OregonScanner
217.20625 Color Code 1 unknown LCN is the control channel for Wipper Hill between Salem and Albany. I haven't had a chance to search for other frequencies for that site yet.
ScanRite
Terrebonne, Oregon
I'm picking up the Timberline channel (previously thought this was Round Butte Dam) from Terrebonne quite well. I'm now picking up site 2.7 from here, 217.31875 maybe this is Round Butte Dam.
kd7jfv
Bend, Oregon
The range for repeater sites in general is not supposed to be more than 25 nm. Per guides from the DB admin supervisors, they generally should be their "intended" service area, not their "listenable" area. I agree, you can hear it for probably 75 miles or more, but that is not the intent of the geo-tagging.
