Pgm Conv
felicia
WACO
i pgm my psr-500 scan list 1 with some CONV-CH and some TGRO-FREQ and than put a lot of CONV-CH in scan list 4 but some went to scan list 1 dose anyone no why
InDICa
Montreal.Ca
Hello Felicia,
It just sounds like you mixed up the scan lists.If you want to see what went wrong?
Download Win500 and then download from scanner.Then go to the tab ALL OBJECTS Tab.And you will see Scan list 1 also has scan list 4 in there also.I could be wrong! But it just sounds like a programming error.Good luck! :)
RoninJoliet
ILL
When you went to SL-4 to enter conv- did you turn off the "*" asterisk in SL1 and turn it back on in SL-4, if not it entered them in SL1 where the "*" was active...Hope this helps....
felicia
WACO
RoninJoliet said:
When you went to SL-4 to enter conv- did you turn off the "*" asterisk in SL1 and turn it back on in SL-4, if not it entered them in SL1 where the "*" was active...Hope this helps....[/QUOT]
i did not turn off the asterisk in sl-1 i just put some conv in sl-1 and then went to sl-4 and put some in there. so i have to turn off sl-1 to pgm in sl-4 then turn it back on.
