Phase 2 systems
Eng86ine
Santa decided I was a good boy this year and made an almost $600 purchase of a Uniden Home Patrol 1
Couple a questions need some help from the scanner pros out there
1. I'm in the South Jersey Area which is going 700Mhz. on APCO Phase 2 system "proposed" for February 2013 -- Will the HP-1 be able to monitor those systems ?
2. With Regards to Philadelphia.....Will it monitor the Systems for PFD and PPD ?
Basically looking to see what type of systems I can expect to monitor between say Trenton NJ to Wilmington Delaware
Finally did santa purchase a $600 paper weight ?
loumaag
Silent Key - Aug 2014
Katy, TX
Post Moved
Your above post was moved from where you posted it. Your post had nothing to do with the thread you posted in, please don't hijack other threads with off topic questions, thanks.
troymail
Silent Key
From what I understand, the Home Patrol isn't able to be upgraded to handle P25 Phase 2.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Currently there is no Uniden model that can handle Phase 2...only the GRE model PSR-800 can (with the firmware update) Mike
