Philly SEPTA Trunked freq's givin me a HEADACHE
So Far Away....
ok,so ive been knocking my skull for 3 days now.
septa,MOTO Smartzone Analog
im using ARC433 to prog my pro 528..
i go to the rad-ref/trunked dwnload window,
then to philly,septa,
select the site theres only 1 to pick
,and then the the groups,
import......
ok,so now im the arc table,,
the freqs are there,,
system settings,,
502.0000-12.5-380
E2-UHF MOTO Type2 UHF
so i ought to be good to go,,right?
nope,,i get that high speed data sound,,
scanner trunk is ON,
antenna is attached,,
batts are good,,
fingers are not broken..
Septa3371CSX1
Drexel Hill, PA
You only need to program 502.4875, 502.5375, 502.5625, and 502.6125. 502.5125 and 502.6625 are MDT channels that should NOT be in the trunk listing. 502.6875, 502.7375, 502.7625, and 502.7875 are conventional channels that should also not be there. You have the correct table settings. Here's my question - do you have the bank set to MOTOrola mode?
So Far Away....
hey,,
there sure diddley are too many freq's in that arc list!
yes,i do have the radio set to MOTO Type2 UHF..
question,,the STATUS BIT and END CODE settings..
ive got STATUS BIT - ON
Do i need to set the END CODE..?
arc433 dose not make those choices,,and MOTO Smartnet needs the stat bit ON..right?
HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
Correction made to the frequency list for the trunked system.
Stuff like this needs to be submitted through the database. Corrections and additions submitted via the forums are not always seem by a DB admin.
