Phoenix Police new precinct boundaries
Astrak
Mesa, AZ
A1 and A2 are just used for in precinct talk traffic or when PD got MDT updates they used those for training. I don't think they're adding any channels or are going to be using anything different than now. 300 will still be dispatched on whatever channel that area is going to be in.
aensr
Surprise, AZ
B02 Talk Group 2808 is up and running, I hear them off the Outlet IR
Units are in the 200 series.
new_to_scanners
Glendale, Arizona
Just when I think I have something figured out, I get confused again.....
I don't get it....There is a Simulcast A, B, and C. So when talk about A1 and A2 and A3 - what is that? How do you know where to add the new talk groups? I just have ABC.....
Astrak
Mesa, AZ
A1, 2,3 etc are channels that Phoenix PD uses. The have ABCD etc decks and that's the channel structure they use.
Astrak
Mesa, AZ
C2=2966, C3=2965, B2=2808, B3=2807, A2=2811, A3=2810.
Channel usage used to be A primary, B secondary and C tactical but now for example 400A is north and 400B is south, or in 900/200 case it's 900/200A is north of Peoria ave and 900/200B is south or Peoria ave and C is still tactical channel.
new_to_scanners
Glendale, Arizona
Thanks astrak it is starting to make more sense now. so 200 is not listed in the database, so I should program in those talkgroups, but I'm not exactly sure where I should put them.....and this is a real nooby question,but i will ask it anyway. do all the talk groups and frequencies have to be programmed in for each section - such as white tanks, quintero, tempe.....OR should I just download the data base and that's good enough? Do you change anything when you download it? I would love to see how you have phoenix set up.
Astrak
Mesa, AZ
Simulcast A will broadcast all Phoenix PD, while the other simulcasts will broadcast maybe some Phoenix PD and other PD's/users. You can program all the talkgroups under each simulcast if you want, but you probably won't hear them all unless you are listening to simulcast A.
What type of scanner do you have? I have the RS 197, so I could send you a WIN500 file and you could look at that.
Astrak
Mesa, AZ
G1-INTEROP Group 1730
G2-INTEROP Group 2849
G3-INTEROP Group 3223
G4-INTEROP Group 2904
G5-INTEROP Group 3224
G6-INTEROP Group 1731
G7-INTEROP Group 3225
G8-INTEROP Group 2847
G9-INTEROP Group 3226
G10-INTEROP Group 1732
G11-INTEROP Group 3222
G12-INTEROP Group 1734
G13-INTEROP Group 2844
G14-INTEROP Group 3227
G15-INTEROP Group 2843
PSAP EAST Group 2852
PSAP Scottsdl B Group 2881
PSAP ApacheJct Group 2880
PSAP ADOT Group 2879
PSAP ASU Group 2878
PSAP Avondale Group 2877
PSAP Buckeye Group 2876
PSAP CAP Group 2875
PSAP Chandler Group 2874
PSAP DPS Group 2873
PSAP East Group 2872
PSAP El Mirage Group 2871
PSAP FBI Group 2870
PSAP GilaRiver Group 2869
PSAP Gilbert Group 2868
PSAP Glendale Group 2867
PSAP Goodyear Group 2866
PSAP MCSO Group 2865
PSAP Mesa Group 2864
PSAP Paradise Group 2863
PSAP Peoria Group 2862
PSAP Phoenix Group 2861
PSAP Scottsdl Group 2859
PSAP SkyHarbor Group 2858
PSAP Suprise Group 2855
PSAP Tempe Group 2854
PSAP Tolleson Group 2853
PSAP West Group 2852
PPD A100 Group 2812
PPD A200 Group 2811
PPD A300 Group 2810
PPD A400 Group 2996
PPD A500 Group 2995
PPD A600 Group 2994
PPD A700 Group 2993
PPD A800 Group 2992
PPD A900 Group 2991
PPD A10 FD LINK Group
PPD A11 TRAFFIC Group
PPD A12 HELO Group
PPD A13 SKY HARB Group
PPD A14 SPEC OPS Group
PPD A15 TALK Group
PPD A16 INFO Group
PPD B100 Group 2809
PPD B200 Group 2808
PPD B300 Group 2807
PPD B400 Group 2980
PPD B500 Group 2979
PPD B600 Group 2978
PPD B700 Group 2977
PPD B800 Group 2976
PPD B900 Group 2975
PPD B10 FD LINK Group
PPD B11 TRAFFIC Group
PPD B12 GANGS Group
PPD B13 SAU Group
PPD B14 SAU Group
PPD B15 TALK Group
PPD B16 INFO Group
PPD C100 Group 2967
PPD C200 Group 2966
PPD C300 Group 2965
PPD C400 Group 2964
PPD C500 Group 2963
PPD C600 Group 2962
PPD C700 Group 2961
PPD C800 Group 2960
PPD C900 Group 2959
PPD C10 Group 2958
PPD C11 Group 2957
PPD C12 Group 2956
PPD C13 Group 2955
EMERGENCY Private 0 0
PHOENIX PD PSAP Private 217872 0
MESA PSAP Private 305872 0
DPS PSAP Private 270715 0
GILB PSAP Private 383872 0
DPS PSAP Private 2707015 0
SCOTT PSAP Private 2707011 0
CAP PSAP Group 2707018 0
SRPD PSAP Private 2707025 0
FBI PSAP Private 2707005 0
PVPD PSAP Private 2707009 0
SKY PSAP Private 144872 0
SUPD/EL PSAP Private 737004 0
TEMPE PSAP Group 847004 0
PSAP Group 2865 53
MCSO PSAP Private 2707117 0
TEMPE PSAP Private 847008 0
PFD PSAP Private 121872 0
PPD? Group 1736 0
PPD? Group 2876 26
A700 DISPATCH 15 Private 215993 0
A500 DISPATCH 14 Private 214995 0
B800 DISPATCH 08 Private 208976 0
A400 DISPATCH 12 Private 212996 0
C800 DISPATCH 10 Private 210960 0
B700 DISPATCH 05 Private 205977 0
B800 DISPATCH 16 Private 216976 0
C900 DISPATCH 16 Private 216959 0
A600 DISPATCH 06 Private 206994 0
C500 DISPATCH 05 Private 205963 0
ARID: 2707007 Private 2707007 0
B400 DISPATCH 03 Private 203980 0
A900 DISPATCH 01 Private 201991 0
B900 DISPATCH 16 Private 216975 0
A900 DISPATCH 10 Private 210991 0
ARID: 302872 Private 302872 0
ARID: 847011 Private 847011 0
B400 DISPATCH 12 Private 212980 0
A800 DISPATCH 08 Private 208992 0
A700 DISPATCH 16 Private 216993 0
A400 DISPATCH 17 Private 217996 0
A800 DISPATCH 10 Private 210992 0
ARID: 142852 Private 142852 0
A800 DISPATCH 16 Private 216992 0
A700 DISPATCH 05 Private 205993 0
A600 DISPATCH 01 Private 201994 0
A600 DISPATCH 16 Private 216994 0
A900 DISPATCH 16 Private 216991 0
ARID: 2707019 Private 2707019 0
C900 DISPATCH 21 Private 221959 0
B500 DISPATCH 12 Private 212979 0
A800 DISPATCH 11 Private 211992 0
C600 DISPATCH 07 Private 207962 0
A700 DISPATCH 27 Private 227993 0
C600 DISPATCH 21 Private 221962 0
A400 DISPATCH 03 Private 203996 0
A900 DISPATCH 05 Private 205991 0
B900 DISPATCH 01 Private 201975 0
A700 DISPATCH 21 Private 221993 0
A500 DISPATCH 05 Private 205995 0
A700 DISPATCH 10 Private 210993 0
B400 DISPATCH 22 Private 222980 0
A800 DISPATCH 07 Private 207992 0
C400 DISPATCH 07 Private 207964 0
ARID: 847007 Private 847007 0
ARID: 2707006 Private 2707006 0
ARID: 2707002 Private 2707002 0
A700 DISPATCH 25 Private 225993 0
ARID: 381872 Private 381872 0
ARID: 2707103 Private 2707103 0
ARID: 385872 Private 385872 0
ARID: 2707008 Private 2707008 0
C400 DISPATCH 10 Private 210964 0
ARID: 307872 Private 307872 0
ARID: 847009 Private 847009 0
PSAP W DISPATCH Private 217852 0
A600 DISPATCH 09 Private 209994 0
C800 DISPATCH 07 Private 207960 0
A700 DISPATCH 17 Private 217993 0
ARID: 146872 Private 146872 0
A600 DISPATCH 21 Private 221994 0
A900 DISPATCH 27 Private 227991 0
A900 DISPATCH 17 Private 217991 0
A400 DISPATCH 04 Private 204996 0
B700 DISPATCH 15 Private 215977 0
A900 DISPATCH 21 Private 221991 0
ARID: 2707107 Private 2707107 0
ARID: 725007 Private 725007 0
ARID: 847006 Private 847006 0
ARID: 2707003 Private 2707003 0
ARID: 2707106 Private 2707106 0
A900 DISPATCH 20 Private 220991 0
B800 DISPATCH 04 Private 204976 0
B400 DISPATCH 04 Private 204980 0
ARID: 384872 Private 384872 0
A700 DISPATCH 07 Private 207993 0
ARID: 847002 Private 847002 0
TEMPE PSAP Private 847001 0
A500 DISPATCH 04 Private 204995 0
ARID: 847005 Private 847005 0
ARID: 2707001 Private 2707001 0
A400 DISPATCH 10 Private 210996 0
A800 DISPATCH 19 Private 219992 0
A600 DISPATCH 05 Private 205994 0
C400 DISPATCH 12 Private 212964 0
B700 DISPATCH 25 Private 225977 0
C700 DISPATCH 05 Private 205961 0
A600 DISPATCH 24 Private 224994 0
ARID: 306872 Private 306872 0
ARID: 2707020 Private 2707020 0
ARID: 202852 Private 202852 0
A900 DISPATCH 02 Private 202991 0
C400 DISPATCH 21 Private 221964 0
A800 DISPATCH 04 Private 204992 0
B900 DISPATCH 05 Private 205975 0
B800 DISPATCH 18 Private 218976 0
ARID: 1049358 Private 1049358 0
B500 DISPATCH 04 Private 204979 0
A500 DISPATCH 17 Private 217995 0
ARID: 1049364 Private 1049364 0
A800 DISPATCH 05 Private 205992 0
C500 DISPATCH 25 Private 225963 0
A400 DISPATCH 09 Private 209996 0
A500 DISPATCH 19 Private 219995 0
A700 DISPATCH 11 Private 211993 0
A700 DISPATCH 06 Private 206993 0
A600 DISPATCH 20 Private 220994 0
A400 DISPATCH 20 Private 220996 0
ARID: 386872 Private 386872 0
ARID: 847003 Private 847003 0
ARID: 2057715 Private 2057715 0
A700 DISPATCH 01 Private 201993 0
ARID: 2058635 Private 2058635 0
ARID: 2057763 Private 2057763 0
B900 DISPATCH 00 Private 200975 0
ARID: 2057573 Private 2057573 0
ARID: 2057421 Private 2057421 0
B800 DISPATCH 10 Private 210976 0
ARID: 2707118 Private 2707118 0
ARID: 2707018 Private 2707018 0
A700 DISPATCH 22 Private 222993 0
C800 DISPATCH 02 Private 202960 0
B600 DISPATCH 06 Private 206978 0
A600 DISPATCH 00 Private 200994 0
C400 DISPATCH 11 Private 211964 0
ARID: 1043756 Private 1043756 0
ARID: 1039738 Private 1039738 0
ARID: 2057714 Private 2057714 0
RADIO TECH Group 1594 474
MESA PSAP Private 30012 0
ASU PSAP Private 2707002 0
PFD PSAP Private 103852 0
TEMPE PSAP Private 847002 0
B500 DISPATCH 14 Private 214979 0
That's what is in my Phoenix PD scan list(minus D,E,F,H decks which I should just take out anyway).
new_to_scanners
Glendale, Arizona
OH. MY.GOSH. I have such a headache now...
So what is Private and the numbers after that?
What is PSAD
What is ARID
Oh my gosh, this is way beyond my level of knowledge....I just thought you create a system, say PRC, then enter all the frequencies, then enter all the groups and that's it.....
does anyone on here have phoenix set up with free scan that they could email a file to me to look at? Astrak, thank you for showing that too me....oh my.
Astrak
Mesa, AZ
Private is just a radio ID that I have alpha tagged you don't have to pay attention to those. PSAP is Public Safety Answering Point it's how all the dispatch centers contact each other and ARID is Automatic Radio ID which is just what WIN500 calls a radio ID when the Automatically log radio ID's box is checked you can ignore that also.
