Phoenix streets city park dept
KB7MIB
Peoria, AZ.
Wirelessly posted (Opera/9.80 (BREW; Opera Mini/6.0.3/27.2354; U; en) Presto/2.8.119 320X240 LG VN530)
AirScan, you really need to invest in a digital scanner. That's just the way it is.
Even if you can't afford a digital scanner right now, look through the database to see who is on the digital systems. Then, ask about specific users if you don't see them.
KB7MIB
Peoria, AZ.
Look for a used GRE PSR-500/600/800 or a used Uniden 396/996T or XT. New models aren't going to be cheap. Even the used ones above will probably set you back $250-300 minimum. That's just the way it is. But I understand. I can't afford any scanner right now. I lucked out being able to buy my PSR-500 when I did.
scanbc780
Usually Lurking
Maricopa/Yavapai Counties, Arizona
AirScan, I can't send you a private message for whatever reason via the forums but if you give me your email I will give you a lead on digital handheld before it gets snagged up for a steal. I almost bought it myself today.
AirScan1
Banned
phoenix Arizona
Uha just 1 thing
What about my favorite dps and aircraft
And none digital frequncies?
Will I still received those?
And what the audio of the scanner
On my scanner app the transmission from phx pd
Sounded kind of broken and buzzed
AZScanner
Somewhere in this room. Right now, you're very col
Another alternative is a pair of SDR dongles, Unitrunker and DSDPlus. They aren't as easy to set up as a "punch in your zip code" scanner like the 436, but with time and patience, you can set up your own homebrew digital "scanner" for about $40 + your own computer. If you're interested, start reading up on them over in the SDR forum. I've used such a set up to monitor the RWC and once I got it dialed in, it worked damn near as well as my $500 436HP does.
-AZ
