Re: Phoenix: what more will I hear with APCO-25 & trunki
NZ7C said:
I am debating about buying a Pro-96. I currently listen to the Phoenix metropolitan area on the public service frequencies of my Yaesu FT-8800 - primarily a Ham UHF/VHF radio. Often while listening referals are made such as: "Go to A-dec channel 8" and the like. Iam wondring if Iwill I be able to hear those "A-dec" conversations and when you setup trunking can the original freq of such a call be linked to the "a-dec" frequency so that you can follow the whole sequence of events? As you can tell I am a Ham operater and not at all scanner literate - so any responses (starting at Scanner 101) would be most appreciated. Thanks in advance. Tim NZ7C
Here's the skinny on the P25 system. My apologies if I cover something you already know:
The old system uses "channels" for operations. Here's a breakdown of their use:
1-North Chase (primarily pct's 6 and 9)
2-Central Chase (pct's 5 and 7)
3-South Chase (pct's 8 and 4)
4-South Mtn Pct
5-Central City
6-Desert Horizon (northeast)
7-Squaw Peak (east)
8-Maryvale (west)
9-Cactus Park (northwest)
10- car to car
11- car to car
12- info
The system also uses some UHF frequencies, called the 450's. 450-1 thru 3 are simulcasts of the chase channels, and 4 thru 7 are mainly used by detectives.
The new system is a totally different concept. Each precinct is now on "decks" A thru E. Due to the encryption in use on the tactical channels it's hard to determine their use right now, but here's what we've learned so far:
A Deck - Dispatch
B Deck - Alternate
C Deck - Tactical*
D Deck - Unknown (Info?)*
E Deck - Unknown (Detectives?)*
* talkgroups are encrypted.
Using this system, "A deck 8" is Maryvale Dispatch. The good news is, using the PRO96 or similar digital trunktracker, yes you can follow these comm's. The bad news is, you're already listening to them! And your Yaesu is tuned in on the more reliable VHF frequencies that can be heard everywhere. There are plenty of places around the valley where my PRO96 goes deaf. Never had that problem with the old system.
Bottom line here is for Phoenix, you actually hear LESS on the new system, due to the encryption being used. So you're really not missing anything. Until the old system is taken offline, I'd stick with what you've got, for Phoenix anyway.
-AZ
