Phone patches
richster
Regina, Sask.
On a standard Motorola 3600 baud mixed mode AstroII system, is it possible for a portable (xts5000) to call another portable on the same system via a phone patch?
Regards,
Richster.
PJH
Are you talking about a direct unit to unit call, or one portable calling another thru the PTSN?
Both are possible. #1 is used everydaythe 2nd would be really inpractical.
N
N_Jay
Guest
richster said:
Impractical, absolutely. But is it even possible?
Regards,
Richster.
Unless someone programmed the switch to disallow it.
My guess is the call would go out to the PSTN and then come back in.
I doubt anyone allows "Extension to extension" calls.
mdulrich
Van Wert, Ohio
To make a phone call to a portable, wouldn't each radio need a phone number or an extension number? Do systems even allow incoming calls to radios? I don't know how systems are set up that have phone patches, so I'm asking?
Thanks,
Mike
Landman
I was a user on a system for several years that allowed exactly what you described. About 99.99% of the time, however they just used private call. Most of the users who had a phone patch enabled on their radios also had private call enabled. On the system that I was on, they allowed the radios to have incoming calls. A person could call a radio by calling a local phone number then entering the radio's 4 digit extension number when prompted. The system was a Motorola type I analog 3600 bps smartnet system.
richster
Regina, Sask.
LOL. I should have read PJH's reply a little more carefully, I would have had my answer a long time ago. Thanks Landman for that personal confirmation, it's make a possible into fact.
Regards,
Richster.
dhutsell
Thanks,
Mike
YES my system allows direct phone calls to individual radios, we have a number for the officers to call and then they enter the radio number of the person they want and it rings right to their phone. Its an XTS 3000 on a type II system (Stone Mountain Park Georgia) in deklab county
DaveH
Ottawa, Ont.
I've seen phone interconnect traffic on a couple of commercial systems (Moto Type I and Type IIi) that show up as I-calls between the system and respective radio (if that makes sense). Two radios could "phone" each other on the same system I suppose, but that would occupy two channels; the patching occurs on dedicated channels. If there's only one channel for this, two radios couldn't call each other in this way. It would be rather inefficient anyway. I don't recall seeing private-call between radios on these systems though.
Dave
