PHP in Server 2k3
KJ4FWA
My own little world
I'm Running a Server With 2k3 Enterprise on it. I Have mySQL Running, but need to get PHP up and working... Anyone Familuar with configuring this? Anyone want to give it a whirl?
bezking
On the Road
It can be a real PITA. Speaking from experience, just use Linux if at all possible. If you have to use Windows, during the PHP install process you MUST manually select the modules to install. If you just select them all the install will finish but execution will fail most likely due to some missing config file, missing program, etc...
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I agree with Bez. And I'll say that i don't believe PHP/MySQL will ever operate as efficiently on Windows as it would on a *nix machine. I really hate dealing with Windows and PHP when it comes to permissions / security either.
If you're only using it as a private server for you, I'm sure it will work fine. If you are going to install it on Windows and make it a public server for all to use, be very careful to do what you can to secure it. This applies to *nix and Windows installs, but even more so to Windows.
mike
KJ4FWA
My own little world
Got all the kinks worked out, Removed a dead HDD, replaced, Swore at it and it started working (with much hard work and far more swearing
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
PHP and MySQL actually run quite well on Windows 2003. There are some benchmarks out there that show PHP and MySQL running faster on Windows 2003 than on Linux. YMMV.
In any case, if you want to install the entire LAMP stack on Windows 2003 very easily, then check out the WAMP Distribution.
Install PHP 5 Apache MySQL on Windows : WampServer
It's the easiest thing known to man.
Good luck!
vabiro
Toronto, Ontario
I have run PHP with IIS and Apache and it works fine with either.
There are going to be compromises to both, but sometimes a move from MS is not an option.
The installer is pretty simple way to address installing for use with IIS., and Lindsay's suggestion for the full LAMP bundle solves a lot of problems.
Victor
