When a pi3 starts 'freezing' the first suspect is an inadequate power supply. Make sure you have one capable of the full 2.2A for micro-USB.@boatbod , ok so the pi 3 keep freezing so I built a laptop (atom processor) on ubuntu 16.04 got it all loaded and seems to be working, but like you said no more then 300 on q... currently says freq 852.775 (-1400). So my question is does the q move the -1400 down with a plus or minus. Not sure how to get in the parameters you said.
./rx.py --args 'rtl' -N 'LNA:47' -S 960000 -q 20 -d -100 -T trunk.tsv -V -2 -U 2> stderr.2
23ppm (~16khz) is quite a lot of correction but not unheard of if you have an older non-temp compensated dongle. The modern TCXO dongles usually hold +/- 1ppm. The other issue is if you do have a non-compensated rtl, the frequency will drift significantly as the unit warms up when you first start op25. It is possible to manage this by adjusting fine tune, but obviously tedious and I really recommend getting better hardware for the $25 approx cost.ok well i am using -q 23 -d 0 but seems the freq seems to move alot , I have to fine turn it when I see the tsbks stop incriminating. Runs good for a bit then stop I change it -100 or plus either way for it to start back up. Is there not auto tune or something once your close?
