Picked up some HT600’s
KJB
First post so Hello and excuse my tardiness!
I’ve played with a couple of 6 channel HT600 for 10 years or so. These are great radios. I got rid of the old laptop I used to program them with - forgot why i even kept it until I needed to reprogram them! But I found a solution that works on Win 7, possibly Win 10 but I haven’t tried. I created a bootable DOS USB drive using a free program called Rufus. Loaded the HT600 RSS on it and it works!!!! I may do a YouTube vid on this.
One question: I’ve heard about moving the channel selector stops but I can’t find any information or pictures of how to do this
petnrdx
Hudson, FL
The switch is six position.
Pull the knobs off, warm up the top of the radio to loosen the sticky stuff holding the escutcheon on, then carefully pry the escutcheon off.
There is a metal hex sided "stop" that you pry loose from the glue.
Then rotate the metal "stop" to the around four o'clock position and stick it all back down.
This assumes that you have the program or the know how to change the radio from a 2 or 4 channel to a six channel.
KJB
Thanks, My radios are 6 channel but I have seen some 2 channels selling for pennies at the flee market before. I may end up picking a few up now that I have the programming down. I have 2to6 saved on a hard drive somewhere.
I’m just now getting back into the old Motos now that I’m semi retired.
Just added the GP300 RSS to my bootable DOS USB drive. Works like 1995! Next stop HT1000
petnrdx
Hudson, FL
I have a dozen P110's too... And probably a dozen VISAR's. Probably several others that I have a dozen of. I REALLY need to get
rid of stuff.
  • Like
Reactions: KJB
petnrdx
Hudson, FL
K9RPL, post: 3497113, member: 1285196"]
Well, I *did* help reduce it just a little...
Yes, you did. And I appreciate that!
KJB
rid of stuff.
Let me know if you want to sell one or two VHF HT600 or other VHF Genesis. Even 2 channel would interest me.
