Picking up HAM Radio
GunnDawg
Is there any easier way to pick up the HAM Channels other than programming them manually in to a bank.
waynesewell
Atascocita (Houston Area), TX
Yes, depending on which specific scanner you are talking about. The 796d/296d have service scans, and ham radio is included in the list of services. Perhaps other uniden and rs models have this.
For the 296D, hit Service, and then 5: Ham Radio.
Note that this post is in the wrong forum. Ham radio is not trunked.
LarrySC
Greenville, SC
Just set up a bank for that and enter the freqs in your area. Much faster to scan what you know than search, and search, and search etc.
nrvate
http://www.arrl.org/FandES/field/regulations/bandplan.html
These are the amateur radio frequency allocations.
You can scan them, and save active frequencies in your area. There really isnt a whole lot of spectrum, so scanning is fairly easy.
if your scanner supports multiple search limit entries, you can program the band limits as search limits.
2m (144-148), 70cm (420-450) and 6m (50-54) are your best choices for scanning, in order of decending activity. it depends on your area I guess, but for sure 2m is the most active. it's the "defacto" amateur band almost every amateur has a rig or 10 for.
73!
