Gamefreak88
- Joined
- Jul 13, 2010
- Messages
- 51
If I have North, South and East control channels programmed in, and lets say Sheriff Rural is only on the East control channel. Since my scanner only has one "system" with all the control channels, and my scanner seems to always be using the South control channel... is it able to pick up Sheriff Rural? In other words, if my scanner finds the South control channel and is happy with it, will it ever check the other control channels (e.g. East)?
My point is, if (because South is strongest where I am at) my scanner always locks on to South, will I EVER hear North or East talkgroups? Can the scanner "listen in" on multiple control channels simultaneously, or does it just pick whichever one is strongest? Because if it does, it will always lock on to South and I'll never hear North or East.
In other words, do I need 3 scanners.. one for each zone?
Isn't STAT mode for stationary? I am rarely stationary. I just now tried STAT mode with "check all CC", and it seems to check all the control channels and it does indeed pick up channels from the North zone (e.g. Sheriff Vista Dispatch and Sheriff Escondido Dispatch), but it is nothing but static and I have to crank my squelch up. This is from home however. Perhaps if I try STAT mode while I'm driving, it will give me what I'm looking for. I'm just concerned that the time it takes to scan the North and East control channels, is signifigant and I will miss out on South radio traffic. Tonight I will do some heavy testing.
EDIT: Sheriff Rural comes in nice and clear on East control channel. I've pretty much only heard Sheriff Rural about a dozen times in two years, and it was usually when I was 40+ miles east of where I live. Interesting find. I will keep playing around.
EDIT (2): This below quote from the Easier to Read Pro-106 manual confuses me. Both sound like they say "hey, lets listen to control channel 1 and check for talkgroup ID's I know" then "hey, lets listen to control channel 2 and check for talkgroup ID's I know", etc.
"Off - the scanner will check a new control channel on each pass, starting with the next frequency in line after the previous pass. It will check only one control channel per pass.
The scanner will park on a different decent quality control channel each time it scans that system.
On - the scanner will park on each decent control channel in the list successively looking for programmed talk groups BEFORE leaving that system and moving on to other system's or conventional channels."
If you use the roam setting, the threshold values are an important part of it. The stat mode with the check all CCs option is a little less complicated to set up.
