pics of #2 discone
merlin-7
Summerville,S.C.
Ok this is my 2nd attempt in a week to build one .
This one is almost all copper, It has a 5 inch disk soldered to a 5 inch brass ring (just because I did not like how flimsy the copper was alone)
I used a 1/4 inch thick insulator made of fiberglass ( I have sheets of the stuff) between the cone and the disk.
5/8 12 inch long copper tubing for the center with pvc slid inside the 5/8 copper.
Inside the pvc is 1/4 inch copper tubing soldered to the disk and inside the 1/4 tubing is all thread that I used to clamp it all together with another fiberglass washer at the bottom.
I hope I explained that clearly enough....
merlin-7
Summerville,S.C.
One odd thing that did happen.
I hooked it up to my rs-95 pro, just sitting like you see it in the picture and at around 154mhz It started playing music ....It seems that it was picking it up from a el-cheapo radio that I had on in the shack at the time...
You should have seen my wifes face when the scanner started playing "I wish you were here" by pink floyd.... :lol: :lol:
