It would be interesting to see pictures of everyones base and mobile antenna setups. Post your pictures if you have them.
mmartinfan said:I think that 1st antenna can cause cancer!
MB said:It would be interesting to see pictures of everyones base and mobile antenna setups. Post your pictures if you have them.
Audiodave1 said:As a general use antenna it works well but anything beyond the 118-512 range is iffy at best if the base station is more than 15mi away.
Of course it excels at the Aero band which is it's primary use.
Dave
What kind of coax are you using? (the red and green stuff).Audiodave1 said:Hey Folks... Attached is my antenna setup which may be moving to a tower if I can find the time... Dave
K8PBX said:What kind of coax are you using? (the red and green stuff).
