Pilot Fire Air Attack
firecaptdave
Watch Duty Reporter
Prescott AZ
Hearing Air Attack from the Pilot Fire on 151.4150. Is that a normal A-G channel? I have it listed as something else. It surprises me that I can hear both sides since I’m in Prescott and not really close (AG freqs aren’t normally repeated.) I do have a little elevation working in my favor (I’m at 5700’)
ETA: does anyone have the comm plan?
GlobalNorth
Fort Misery
It isn't all that distant from Prescott and as a 16,000+ acre fire, it's going to require a lot of resources including comms.
Incident Type: Wildfire
Updated: 2023-07-07
Map which features the pilot fire at its center and lines from there outward depicting distance to various cities in Arizona
KB7MIB
Peoria, AZ.
Ravenfalls
Couple years ago did some tower searching. It showed state land Tac channels as repeaters along the az/CA strip.
Fired, found all kinds weird Freq. California recently changed few channels. CA crews will use those Freq, travel & camp talk around.
Many engines have VRS. Engine repeater will provide coverage few miles. VRS can also allow portables to talk back to their home radio system via FirstNet. Cool technology!
firecaptdave
Watch Duty Reporter
Prescott AZ
151.4150 is Arizona Department of Forestry and Fire Management channel 2. Channels 1-8 are repeaters. That particular channel has a repeater atop Mingus Mtn, as well as a few other locations.
John
Peoria
Thanks John. It showed as something else on my scanner, so I might have programmed it wrong (although I downloaded it from RR.) Also, I didn’t think AG freqs are normally repeated so that surprised me. I’m likely high enough to hear the aircraft but not the ground unit, if it were simplex.
