Pinellas County P25 (802)
batdude
East Central, Florida
trying to figure out the sites for Pinellas County. Some of this is just opinion ... so YMMV.
reference: Pinellas County Trunking System, Pinellas County, Florida - Scanner Frequencies
Their FCC licenses... of which there are several, seem to be set up as a Simulcast-like system .... which isn't what they seem to have on the air.
I will start with Site 1.12 (the 700Mhz site) - which seems to be correctly licensed as WQLM585 and operating on three channels (769.10625, 769.50625 and 770.00625) - per their license, this site appears to be a three-site simulcast...with sites in Largo, St. Pete and Tarpon Springs.
The other sites.... seem to be a complete mess between all of these licenses:
That said - there is at least SOME consistency between all of these licenses and mapped out sites (also note that the 3 700mhz sites "fit" this map as well:
The frequency structure of the licenses and the data that I see on DSD+ does not indicate a simulcast system, per se - mainly since all of the sites use different frequencies, but at least "by the data" - they operate a 6 site system.
Can someone out that way with DSD+ take a run on each of the Pinellas sites and post the data (either here or send to me via PM if you wish to remain anon?
It would also be nice to know which site goes to which location > like "1.2 is XYZ City".
Here is the data from my DSDPLUS.P25 data file that I am looking for (keep in mind, I am a good distance from Pinellas County, so MY DATA IS NOT 100%.
Network: BEE00.802 ; Pinellas County
Bandplan #0: Base=851.00625 Offset=-45 Spacing=6.25 BW=12.5
Bandplan #1: Base=769.0125 Offset=+30 Spacing=6.25 BW=12.5
Site: 1.2
Channel 0-85: 851.5375 CC
Site: 1.4 NAC=800
Neighbor: BEE00.802-1.2
Neighbor: BEE00.802-1.5
Neighbor: BEE00.802-1.10
Neighbor: BEE00.802-1.12
Channel 0-833: 856.2125 VOICE
Channel 0-913: 856.7125 VOICE
Channel 0-949: 856.9375 SCC
Channel 0-1073: 857.7125 VOICE
Channel 0-1101: 857.8875 DATA
Channel 0-1109: 857.9375 CC
Channel 0-1153: 858.2125 VOICE
Channel 0-1269: 858.9375 SCC
Channel 0-1429: 859.9375 SCC
Site: 1.5 NAC=800
Neighbor: BEE00.802-1.4
Channel 0-31: 851.2 SCC
Channel 0-93: 851.5875 VOICE
Channel 0-97: 851.6125 SCC
Channel 0-173: 852.0875 VOICE
Channel 0-873: 856.4625 VOICE
Channel 0-917: 856.7375 VOICE
Channel 0-953: 856.9625 CC
Channel 0-1113: 857.9625 DATA
Channel 0-1193: 858.4625 VOICE
Channel 0-1213: 858.5875 VOICE
Channel 0-1237: 858.7375 SCC VOICE
Channel 0-1397: 859.7375 VOICE
Site: 1.10
Channel 0-1433: 859.9625 CC
Site: 1.12 NAC=800 BSI=WQLM585
Channel 1-15: 769.10625 CC
Channel 1-79: 769.50625 SCC
Channel 1-159: 770.00625 DATA BSI
chief21
Summer - Western NC; Winter - Tampa Bay FL
Short answer... The Pinellas "sites" are not physical sites; rather, each site is a separate wide-area radio system. Most (perhaps, all) of those systems are multi-location simulcast.
Site 5 is primary for most agencies and I believe site 4 is primary for St Petersburg. I think the other smaller sites are special-purpose.
RYGDWW
Pinellas
Good info. Currently setting up my new SDS100. Is there a speed of scanning advantage to omitting sites 1, 2, and 3 if the targets for scanning are the larger agencies?
chief21
When scanning trunked systems, the fewer sites/systems that have to be cycled through, the faster the overall scanning will be. Each separate control channel must be acquired and briefly monitored for valid activity before the scanner can move on to the next site/system.
k3baz
Cockeysville, MD
I've been monitoring Site-005. For the past several days I've been seeing control traffic in 856.9625 instead of the main control channel in the database of 851.200. Is there something going on with 851.200 or does the database need to be updated?
zlandmedia
Tampa. FL
856.9625 is highlighted in blue on the database listing, which means it's an alternate control channel. It's not uncommon for control channels to move around on a system.
FL2WAYRF
Motorola subscribers can determine these alternate CC's. Harris on the other hand, needs them all entered.
