Pinellas Sheriffs & St. Pete PD
Tryton
Largo, Fl
I will be ordering another Scanner within a month, Once I do, I will start feeding these unless someone else does first. Until then, you can listen here to my server. I will be keeping it up for awhile. It will not be dedicated, but until the new scanner comes...
If there is some other Agency you would like me to add, just ask.
Private Scanner Server
Behind a firewall?
http://65.32.85.146:420
Enjoy!
Tryton
Largo, Fl
Just a quick update, I am only scanning the Pinellas county Sheriffs office. Also, If you are behind a firewall that will not allow you to access the site. You can just use the IP address. You no longer need the port number. http://65.32.85.146
Hope you like it!
David
Nice Job, I like that you kept North County on seperate feed.. I quess RR made u take down LE channels ?
David
I would think the LE channels would be ok, they are just patches or inter Ops mutual aid.. i know it is out of your control. Thank you for the feeds..Great Job
