I host two Broadcastify scanner feeds, using ProScan and RadioFeed. I get multiple similar error codes several times a day on both feeds, and can't seem to pinpoint whats going on.
They usually start with Error Code 10- "Unable to write data to the transport connection. An existing connection was forcibly closed by the remote host."
Afterwards within a one minute span, i get about 4 "Error code 1- Unable to connect to Broadcastify server."
Sometimes after the Error code 10, i'll get an Error code 3- Mountpoint in use.
System is direct connected via ethernet cable to an Apple Airport router. I don't believe this is associated with the computers hardware, as i had recently upgraded computer systems, and the problem followed it.
I had downloaded and ran Ping Plotter and was able to capture data while experiencing the problem. Unfortunately i don't really know how to decipher it. It looks to me that the problem is on my ISP's side, am i correct?
