Pinout
sbkeith
Here's a question for you M/A Com gurus.. What is the pinout on the accessory port of the standard M/A Com system head (Orion/M7100/725M series) for the speaker connection?
I would like to make my own speaker adapter cable and get rid of this 4 feet of 1/2 in. cable. Any ideas?
Scott
nhiester
Beavercreek / Bellbrook
Here ya go. Listed from pin 1 to Pin 25
1: Sup Gnd
2: XDATAIN
3: XDATAOUT
4: RS485+
5: RS485-
6: CTS
7: GND
8: HKSW
9: OUT2
10: IGN SEN
11: MIC HI
12: ALO
13: VOL HI
14: CTLON
15: XTONENC /SONOFF
16: XTONDEC /SDATA
17: RQST
18: SPKR1
19: SPKR2
20: RTS
21: INP1 /HORNRING
22: OUT1
23: INP2
24: EXTMIC
25: SW A+
You should use pin 18 and 19 for external audio. Do not ground the speaker as this is a floating circut.
nhiester
Input 1 and/or Input 2 whichever the radio has been programmed for. Couple either one with Pin 7: Ground and the radio will key up. But you have to program the input you want for PTT
buckindb
nhiester: is there a method to determining which input was programmed for PTT on my radio?
nhiester
You can take either of the inputs to ground and see if they key up the transmitter. If they are not programmed to PTT, they will just emit a low short beep
