RULE OF THUMB ... If you cannot hear an active control channel while advancing through the programmed frequencies in "manual" mode, you will not be able to trunk-track the system, either.
If you don't hear the control channel data ...
- check and make sure all the site frequencies are programmed in
- try a different antenna
- try listening from a different location
- make sure none of the site frequencies are locked out
- make sure you have the trunking type set for both the frequencies and the bank
- if in "scan" mode, make sure you have some talkgroups programmed in the scanner
(some of the above only apply to certain scanners)
Jeff Multer
