Piscataway
robocop80
Concord CA
Anyone out there listening to piscataway police? I cant seem to pick up a thing. I am in north brunswick so maybe im too far but im getting nothing at all
Highpockets
Toms River, New Jersey
You entered it as a Motorola uhf system, entered the base, spacing and offset settings and your getting nothing, did you enter id's or are you searching, (open or closed mode on newer radios?)
robocop80
Concord CA
I entered the following freqeuncies 500.48750 500.53750 500.71250 500.98750 501.33750 in UHF mode. I have 500.2375 listed as the base with 25.0 spacing Offset 380. I didnt enter ids, do I need to enter ids? I have the scanner in search ID mode. Any suggestions
DJ88
Brick Twp., New Jersey
When scanning, does the scanner stop for a second on the control channel and then start scanning again or does it just scan right through the system? If it stops n the control channel, that means you have it programmed correctly. If not, you either have it programmed wrong or you're too far away to pick up the control channel, and without that (control channel), you can't receive it.
robocop80
Concord CA
It just scans throught the system.I think I may be to far. I will try it out in Franklin and see if I can pick it up if I cant then something is wrong.
