Out in Pitt County this weekend for the kickoff of college football and I have discovered that the new 700 MHz P25 system is now on the air. I'll be adding it to the database shortly. The tables support Phase II TDMA operations. It looks like it'll be a while before the system is put into use, every public safety worker I saw today had an XTS2500 on their hip. They may move over to Phase I operations for a while, or may stay on VIPER for the next few years until making a full switch.
I've ran Pro96Com for a little while and I'm not seeing any affiliations at all, so it's probably still a very new system. Those of you with P25 capabilities, now would be the time to add it into your scanner and search/wildcard and listen for traffic.
[System]
SystemID=1207
SystemIDHEX=4B7
WACN=BEE00
Description=Pitt County 700 MHz
[Towers]
101=Greenville
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 4B7
System Name : Pitt County 700 MHz
WACN : BEE00
Tower Number (Decimal): 101
Tower Number (Hex) : T0101
Tower Description : Greenville
Control Capabilities : Voice,Registration
Call Sign(s) : CHANGEME
Timestamp : Sat Sep 1 18:05:13 2012
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1
01,762.00625,0.00625,30.00000,"Confirmed",0.00625,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,935.01250,0.01250,-39.00000,"Confirmed",0.00625,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"01-1690","i",772.56875,"01-1690",802.56875,0,1
"01-1910","a",773.94375,"01-1910",803.94375,0,0
"01-1954","a",774.21875,"01-1954",804.21875,0,0
"01-1994","a",774.46875,"00-0000",851.00625,1,0
"01-2034","c",774.71875,"00-0000",851.00625,1,0
[System]
SystemID=1207
SystemIDHEX=4B7
WACN=BEE00
[Towers]
101=Greenville
-TowerInfo
System ID : 4B7
WACN : BEE00
-Tables
-Frequencies
