Anytone PL Encode weirdness on the AT-5888UV
N9JIG
Sheriff
Moderator
Far NW Valley
I came across a weird thing on my AT5888: When the left side is in VFO mode and set to encode CTCSS or DCS (but NOT to Decode) it will not transmit the PL or DPL code, it just transmit in CSQ. Programmed memories work properly.
The right side works fine, the issue is only the left side.
Has anyone else seen this on their radio? If you have one can you see if it happens to you?
N9JIG
Sheriff
Moderator
Far NW Valley
An update:
I reinitialized the radio and tried VFO only, it worked fine.
I reloaded my original codeplug to the radio and the same issue appeared.
I recreated the programming with a dozen or so channels and it works fine.
My conclusion is that there is something weird set in the original codeplug. I went thru the various settings and cannot find anything that would cause it but there has to be something...
