PL Hum question.
62Truck
Ordinary Subscriber
Uranus
Ok on my HT1250 I can hear the PL audio and it is very annoying at times, some channels its ok and other its just over whelming, is there a way to fix this with the Global Turner or somthing?
62Truck
Ordinary Subscriber
Uranus
It should work with the CDM series being that they are pretty much the same radio.
62Truck
Ordinary Subscriber
Uranus
Ok I just retuned my HT1250, there is a little hum still there, not a big problem, but it also did cure another problem i was having with the counties alerting tones coming across distorted
Josh
Auburn Hills, Michigan
tada.
You may not be able to get rid of all of it, especially depending on what PL tone is being used, but you can make it less of a problem. Radios should come out of the factory set that way.
62Truck
Ordinary Subscriber
Uranus
Yeah I know, its funny I never had any problems when I had my VHF 1250, this is my first UHF one, I am having it re-flashed with a newer firmware, so maybe that might take care of it.
CommJunkie
FN20jf
I never knew what the hum was until now. It only appears on one channel. I thought it was a radio problem since it's not prevalent on any other radio. Is this Global Tuner another program or is it a feature of the CPS? (I do have access to the CPS software)
62Truck
Ordinary Subscriber
Uranus
The CPS that I have which is probably the newest came with the global tuner, the global tuner can be found easily on the web.
john9912
If your firmware is version 4.xx or earlier, then I would suggest a firmware upgrade. The earlier versions of firmware had similar audio issues reported.
