critter449
i know that the FCC assigns frequencies but i was just wondering who assigns a pl or dpl to a frequency. is it the FCC who does this and if so why are the pl or dpl tones not given on their website.
PLs are tones. DPLs are codes, not tones.
Regarding the DPL false-decoding PL131.8, I've seen it happen in some PL decoders. It's more of a problem with PL136.5 since a DPL code is sent at 134.4 bits/sec. The "turn off" code at the end of a DPL-encoded transmission sounds like a 134.4Hz tone, causing at PL136.5 PL decoder (and sometimes 131.8) to falsely decode it as a valid PL tone. This is often referred to as the DPL kerchunk problem.
My favorite PL tones are tones in the middle of the range and I avoid using tones known to be problematic.
- I avoid all tones below 100.0 Hz due to some noise sources causing decoders to false-decode plus some false decode on adjacent tones. I've witnessed a case where a PL decoder set for 74.4Hz was false decoding on 71.9Hz and 77.0Hz tones. The higher tones don't suffer from this due to them being spaced farther apart in frequency. Some PL decoders are better than others.
- I avoid tones that are close (within +/- 2 Hz) to harmonics of 60Hz: 118.8Hz (2nd harmonic at 120.0Hz), 179.9Hz (3rd harmonic at 180.0Hz)
- I avoid 131.8Hz and 136.5Hz due to the DPL kerchunk problem.
- I avoid all tones above 167.9 due them being more audible and annoying. I've also witnessed voice frequency components falsely tripping some PL decoders set to decode the higher tones. Ever listened to 254.1Hz? It's a real screamer of a PL tone!
My favorites are: 123.0, 127.3, 141.3, 146.2, 151.4, 156.7, 162.2, 167.9. I use 141.3 as my default tone.
Good luck.
Lots of good info there, thanks for posting it.PLs are tones. DPLs are codes, not tones.
Good luck.
