What is a Pl tone?
LarrySC said:PL tone is a squelch lock. If 3 fire depts are in a triangle from your location on the same frefq you would hear all three. If you PGM freq and PL tone for the one you want to hear, then you will not hear the other 2. Short answer.
USAPatriot said:Question then...other than for excluding unwanted transmissions, is there any point in programming the tones in? -Rod-
nexus said:Nope. No other reason or purpose. It's sole job is to seperate unwanted signals you're not interested in hearing.
Voyager said:Well, it also eliminates squelch tails.
Joe M.
jmp883 said:Once you go PL/CTCSS you'll never go back!!:twisted:
so If I dont have one of 'those' scannersJoseph11 said:Most scanners have PL search functions. For example: If I sit on a frequency and switch my PRO-92 into "PL" mode, when someone keys-up, I'll get the PL tone they're using in about 1 second (provided they transmitted long enough).
BTW, PL tones are in Hertz (Hz), not Kilohertz (kHz).
waiting to win the lottery, so I can get the 396T.. :lol:drew6553 said:yea maybe unless you upgrade and get a pro 97 to go with your 95 and 83 i know the 97 has a ctcss mode setting in the banks
I also agree, this is why I don't own a Pro-95. I thought it was a step backward in technology from previous trunking scanners by RS.jmp883 said:Once you go PL/CTCSS you'll never go back!!:twisted:
Hmm, mine take less time than it takes for the person to start speaking, it is instant in all my Pro-92/2067 radios.Joseph11 said:...If I sit on a frequency and switch my PRO-92 into "PL" mode, when someone keys-up, I'll get the PL tone they're using in about 1 second (provided they transmitted long enough).
If the police are transmitting, they're still "covering up all of the guys transmissions on my scanner" - you just don't hear it.ILbandit said:I used to moniter a customer in Chicago that I frequented, they use low power FM walkie talkie type transmitters to talk to each other inside the chemical plant. But the local police were on the exact same frequency It was hard to moniter the workers in the plant, because the police were constantly talking and covering up all of the guys transmissions on my scanner. I set it to PL mode, got their Tone, programed it in, and didn't ever hear the police again. Blocked everything out except the guys in the plant ONLY.
