Multiple towers on the hill in Concord have collapsed from todays weather. NOAA is online , P575 is offline, capital fire is down a site just to name a few.
Was that giant piece of cement buried in the ground up to the white edge?
That should say Plausawa Hill, FYI.
Yes, that is (was) the foundation. About 10' from end end. Ripped it right out of the ground and dragged it 10 feet. Amazing power. Tore the steel mounting bracket on one of the other legs, about 3/4"-1" thick steel plate.
They still use 37.58 repeater? Or don’t they use that at all? I know it’s listed as that for their frequency, so not sure if they are still using that frequency on a repeater?
There are quite a few towers I've seen with this type of base. Especially larger ones. If done correctly, the tower would be just as strong.I've never seen a free standing tower with a block of cement for each leg. Should be one massive concrete slab underground with the pears tied to it.
Typically when a tower fails, it is due to one of the following:
