Please help me find...
diarrheaman
I cannot find the frequencies/channels for the police department in my area(Tiburon, CA). I know the "DEC" is16816. Can someone tell me what the frequencies they use are? Thanks!
D
DaveNF2G
Guest
Try the California forum and the RR database under California.
Thanks, but all I get there is the DEC #, not the frequency. Any suggestions?
The frequency are just before you get to the TG ID's Make sure you you program each site separate or if you keep the scanner at home program the site you are in only.
diarrheaman
I still cannot find the frequency for this area (Tiburon, CA) where you mentioned. Can you send me a link to it or if you see it tell me the frequency please? Thanks for your help!
did you click on Highpockets link he gave ?
when you scroll down you get to the following and Tiburon should be in the East Zone.
Program all Frequency (What Scanner are you using ?) into your System and from there you add or scan for new talkgroubs for Marin MERA or just the ones you want to listen to.
If you need help understanding trunk System look in the Wiki area of the Website.
By the way 16816 shows as Tiburon DPW Public Works
System Frequencies
Red (c) are primary control channels | Blue (a) are alternate control channels | Site Map(s): FCC Callsigns RR Locations
Site Hex Name Freqs
001 1 East Zone 482.35000 482.62500 482.65000 482.78750 482.93750 483.02500a 483.12500a 488.70000c
489.07500c
002 2 West Zone 482.97500 483.05000 483.15000a 488.42500a 488.85000a 489.10000c
003 3 Sonoma Mtn IR 482.32500 488.40000a 488.47500a 488.72500a 488.87500c
004 4 Bodega Bay IR 488.97500 489.32500 489.70000 490.10000c 490.72500
005 5 Bolinas IR 483.02500 483.95000 488.47500 489.45000c 490.80000
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
Your area isn't working on a "frequency" like you think they are. They're on a trunked system where the "DEC" ID is used to identify their communications. If you can tell us which scanner you're using people can assist you better.
I would recommend looking over the RadioReference Wiki and reading up on trunked radio systems to assist you in understanding how they work. [Up at the top of the page is "Wiki", in between Forums and Classifieds. Hover you mouse over it to show the drop-down list, then click Trunking]
