Introduction to Programming the Uniden BC246T
Here is a quick step by step guide to programming the BC246T:
To clear all the default data, while turning the radio on, you need to be holding down the “hold”, “2” and “9” buttons to reset the memory (while also holding down the power button).
After the memory is clear, you need to hit the ‘menu’ button on the left side of the radio. When it displays “Program system”, hit the “E” key. Then hit “E” on “new system” and then hit “E” for Conventional system. Hit “E” when it asks to confirm yes or no.
Scroll to “edit group” and hit “E”. “new group” and hit “E”. scroll to edit channel and hit “E”. “New channel” and hit “E”. Then enter the frequency and hit “E’. Then hit “menu” to go back a level and scroll until you see “new channel” again and repeat the process until you’ve entered in all the frequencies you want to monitor. Use the “menu” button whenever you need to step back to the previous menu.
This is a very brief introduction. If you need help or want more info, please reply. You can add alpha tags to the frequencies too by using the “edit name” option. I use the Butel ARC246 software to program my radio and it is a lot easier than programming the radio by hand if you plan to program in many systems.
Also, this page will be of interest to you:
http://www.radioreference.com/modules.php?name=RR&ctid=334
I don't know if your city is patrolled by the county sheriff of if the city has their own pd. The Radioreference.com database doesn't show any frequency for your city, but you can try 155.805 and see what you here on there.
Hope that helps. The BC246T is a great radio.
