Reference System: ERS Wireless Indiana Trunking System, , Indiana
***Assume the system above is not documented and everything was collected from scratch as I am learning to document without help from the RR database***
I've read somewhere that this system is going to eventually replace the one found here. I thought I might try to get a head start on contributing to its page. I have matched a few frequencies to their channels so far but they system only seems to have one... active... talkgroup at this time. I was hoping someone would be able to double check my formatting and workflow as I've never worked with Capacity Max before.
After reading the dsdplus.txt, I was able to find the section on "DMR TIII handling". Following its guide, I first connected to Site 003 (3). This gave me the SysCode for Site 3 as well as the SysCodes for the neighboring sites of 1, 4, 8, 9, 11, 16. The results are below:
I then got a little confused with this section:
I tried replicating the format that was used in the example by having the Service Area as 5 bits and the Site Number as 3 bits.
I continued with updating the DSDPlus.networks file:
DSDPlus did not like this format. I tried "TIIInonStd" because I noticed that it auto decoded each of the control channels to this and it worked:
I went on to the DSDPlus.sites file and entered the following:
After all of that I sat on a control channel and waited for some channel numbers to pop up. I found their corresponding frequency and entered it like so:
I re-verified that the match was correct and moved on. All were listed as "nonStd" until I came across a different site that DSDPlus was decoding automatically as "TIIIStd". I tried entering it as:
An error told me this was the wrong format so I forced it to nonStd and that seemed to work. What I found really annoying was the frequency for Ch 2032 sits right on top of a decently strong NEXEDGE control channel.
So this is my process so far. I am very open to suggestions and critique as I am trying to get better.
Code:
10.1010.00000001
10.1010.00000011
10.1010.00000100
10.1010.00001000 (These are in no particular order)
10.1010.00001001
10.1010.00001011
10.1010.00010000
To determine the correct field sizes, gather as many SysCodes as possible by monitoring system sites and examining their neighbor lists ... It becomes clear that the SysCodes should be decoded as (example given).
Code:
CC
10.1010.00000 001 163 NID=11 Area=1 Site=2
10.1010.00000 011 NID=11 Area=1 Site=4
10.1010.00000 100 499 NID=11 Area=1 Site=5
10.1010.00001 000 1971 NID=11 Area=2 Site=1
10.1010.00001 001 2019 NID=11 Area=2 Site=2
10.1010.00001 011 2033 NID=11 Area=2 Site=4
10.1010.00010 000 1 NID=11 Area=3 Site=1
TIII, L10, "ERS Wireless Indiana", 5DSDPlus did not like this format. I tried "TIIInonStd" because I noticed that it auto decoded each of the control channels to this and it worked:
TIIInonStd, L10, "ERS Wireless Indiana", 5I went on to the DSDPlus.sites file and entered the following:
Code:
; ERS Wireless Indiana
TIIInonStd, L10, 1, "Location ?" ;CC 163
TIIInonStd, L10, 2, "Location ?" ;CC 583
TIIInonStd, L10, 3, "Fort Wayne, IN" ;CC 525 454.2750 DCC 0
TIIInonStd, L10, 4, "Location ?" ;CC 499 454.1125 DCC 0
TIIInonStd, L10, 5, "Location ?" ;CC 2203 464.7625 DCC 3
TIIInonStd, L10, 8, "Location ?" ;CC 1971
TIIInonStd, L10, 9, "Location ?" ;CC 2019
TIIInonStd, L10, 10, "Location ?" ;CC 127
TIIInonStd, L10, 11, "Location ?" ;CC 2033 463.7000 DCC 9
TIIInonStd, L10, 16, "Location ?" ;CC 1
TIIInonStd, L10, 3, 562, 454.5000, 0.0, 0I re-verified that the match was correct and moved on. All were listed as "nonStd" until I came across a different site that DSDPlus was decoding automatically as "TIIIStd". I tried entering it as:
TIIIStd, L10, 4, 2032, 454.7125, 0.0, 0An error told me this was the wrong format so I forced it to nonStd and that seemed to work. What I found really annoying was the frequency for Ch 2032 sits right on top of a decently strong NEXEDGE control channel.
