Please
ThornyO5
japan
Can someone define
What is an example of what RM means? I know it repeater mobile but...
Also what is fixed?
Does RM mean the repeater and mobile are on the same freq. or... thanks.
Tweekerbob
RM (and somone correct me please if I'm wrong) is typically the output of a repeater. This is typically the frequency you will want to listen to.
The input is usually CO.
Fixed is either a COntrol point or could be used in point to point communications. Basically one tower relaying to another tower. These are usually at least UHF if not in the microwave range.
Ryan
FPO703
Planet Earth
RM means that the system uses a repeater and the mobiles can transmit on the repeater output usually in simplex mode, as well (kinda like a talk-around). Fixed is usually for RF links. AKA Remote input sites.
Tophtoh
Holland, Ohio
I apologize but, I guess I'm not understanding, EX: my sheriff dept. TX's on 465.475 and RX's on 460.475, would that be an example of Repeater or Repeater mobile. Thanks
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Unless you have plans on being a by-stander at an incident, program
the 460.xxx freq's in your scanner.
Tophtoh
Holland, Ohio
Thanks, but I am aware what a input and a output are, what I am asking is, Take 460.475 output, would this just be R? 465.475 input, is this M? Therefore does it make it RM?
W4KRR
Coconut Creek
ThornyO5 said:
Can someone define
Also what is fixed?
Could you give an example of where and how you saw the "RM" used? In the context you used, I don't think it stands for "repeater/mobile" as those are two different things. The repeater and mobile cannot be on the same frequency, so I doubt that's what RM stands for.
N
N_Jay
Guest
W4KRR said:
ThornyO5 said:
Can someone define
Also what is fixed?
If it is in teh FCC ULS database it probably means "Renewed/Modified"
N
nmfire10
Guest
You need to do 2 things or this discussion is going to accoplish nothing.
1. A topic that is somewhat descriptive would help. I know plenty of people that will simply skip topics such as this because the subject is usless.
2. What database are you looking at that is indicating RM? That could meany many things in many databases. It's like asking "What does the H mean on 'the gauge' on your car's dashboard. There are lots of gauges with an H. Be specific.
BJ_NORTON
Las Vegas
I know what your talking about. I asked about it a year or two ago on the www.strongsignals.net board. Someone there posted a link to a help page on the FCC site that definde what all those terms meant, M, RM, FX, FX1,FX2...etc, but the quick search I did, didn't produce any results. I printed them out at one time and had them taped to my desk, but the list got trashed when I moved to Vegas, and my hard drive crashed 2 months ago, so I lost the bookmark. I waill try to look around on the FCC site, and I suggest you do the same. as they say, "the truth is out there".
nd5y
Wichita Falls, TX
I think the RM they are talking about is the RadioReference.com database
codes not the FCC ones. The FCC does NOT use R or M.
Tom
nd5y
Wichita Falls, TX
Somebody can take these and make a sticky or put them in the Wiki or something.
Tom
Class Station Code
AOX Operational Fixed
APC ALASKA PUBLIC
APX ALASKA PRIVATE
APX2 ALASKA PRIVATE (TEMPORARY)
AX AERONAUTICAL FIXED
AX1 AERONAUTICAL FIXED (MOBILE)
AX2 AERONAUTICAL FIXED (TEMPORARY)
DGP DIFFERENTIAL GPS
ELT ELT TEST
ELT1 ELT TEST (MOBILE)
FA AERONAUTICAL ENROUTE
FA1 AERONAUTICAL ENROUTE (MOBILE)
FA2 AERONAUTICAL ENROUTE (TEMPORARY)
FAA AERONAUTICAL ADVISORY (UNICOM)
FAA1 AERONAUTICAL ADVISORY (UNICOM) (MOBILE)
FAA2 AERONAUTICAL ADVISORY (UNICOM) (TEMPORARY)
FAB AUTOMATIC WEATHER OBSERVATION
FAC AIRPORT CONTROL TOWER
FAS AVIATION SUPPORT INSTRUCTIONAL
FAS1 AVIATION SUPPORT INSTRUCTIONAL (MOBILE)
FAT FLIGHT TEST
FAT1 FLIGHT TEST (MOBILE)
FAT3 FLIGHT TEST (ITINERANT)
FB Base
FB2 Mobile Relay
FB2C Mobile Relay - Interconnect
FB2I Mobile Relay - Itinerant
FB2J Mobil Relay - Temporary Interconnect
FB2K Mobile Relay - Stand-by Interconnect
FB2L Mobile Relay - Itinerant Interconnect
FB2S Mobil Relay - Stand-by
FB2T Mobile Relay - Temporary
FB4 Community Repeater
FB4C Community Repeater - Interconnect
FB4I Community Repeater - Itinerant
FB4J Community Repeater - Temporary Interconnect
FB4K Community Repeater - Stand-by Interconnect
FB4L Community Repeater - Itinerant Interconnect
FB4S Community Repeater - Stand-by
FB4T Community Repeater - Temporary
FB6 Private Carrier (profit)
FB6C Private Carrier (profit) - Interconnect
FB6I Private Carrier (profit) - Itinerant
FB6J Private Carrier (profit) - Temporary Interconn
FB6K Private Carrier (profit) - Stand-by Interconne
FB6L Private Carrier (profit) - Itinerant Interconn
FB6S Private Carrier (profit) - Stand-by
FB6T Private Carrier (profit) - Temporary
FB7 Private Carrier (non-profit)
FB7C Private Carrier (non-profit) - Interconnect
FB7I Private Carrier (non-profit) - Itinerant
FB7J Private Carrier (non-profit) - Temporary Inter
FB7K Private Carrier (non-profit) - Stand-by Interc
FB7L Private Carrier (non-profit) - Itinerant Inter
FB7S Private Carrier (non-profit) - Stand-by
FB7T Private Carrier (non-profit) - Temporary
FB8 Centralized Trunk Relay
FB8C Centralized Trunk Relay - Interconnect
FB8I Centralized Trunk Relay - Itinerant
FB8J Centralized Trunk Relay - Temporary Interconnect
FB8K Centralized Trunk Relay - Standby Interconnect
FB8L Centralized Trunk Relay - Itinerant Interconnect
FB8S Centralized Trunk Relay - Standby
FB8T Centralized Trunk Relay - Temporary
FBA Small Base
FBAT Small Base - Temporary
FBBS Base
FBC Base - Interconnect
FBCT FBCT
FBGS Ground
FBI Base - Itinerant
FBJ Base - Temporary Interconnect
FBK Base - Stand-by Interconnect
FBL Base - Itinerant Interconnect
FBS Base - Stand-by
FBSI Air-ground Signaling
FBST Standby
FBT Base - Temporary
FC PUBLIC COAST
FC2 PUBLIC COAST(TEMPORARY)
FCA MARINE SUPPORT-TESTING & TRAINING
FCA2 MARINE SUPPORT-TESTING & TRAINING (TEMPORARY)
FCL PRIVATE COAST
FCL2 PRIVATE COAST (TEMPORARY)
FCU MARINE UTILITY
FCU1 MARINE UTILITY (MOBILE)
FIS Flight Information Services
FIS1 Flight Information Services with Hand Held/Mobile
FIS2 Flight Information Services for Temporary Operatio
FLT Auxilary Test
FLTC Auxiliary Test - Interconnect
FLTI Auxilary Test - Itinerant
FLTL Auxilary Test - Itinerant Interconnect
FLU AVIATION SUPPORT SERVICE
FLU1 AVIATION SUPPORT SERVICE (MOBILE)
FMA1 AIRCRAFT FLIGHT TEST STATION
FX Fixed
FX0S Operational Fixed - Stand-by
FX1 Control
FX1C Control - Interconnect
FX1I Control - Itinerant
FX1J Control - Temporary Interconnect
FX1K Control - Stand-by Interconnect
FX1L Control - Itinerant Interconnect
FX1S Control - Stand-by
FX1T Control - Temporary
FX2 Fixed Relay
FX2C Fixed Relay - Interconnect
FX2I Fixed Relay - Itinerant
FX2J Fixed Relay - Temporary Interconnect
FX2K Fixed Relay - Stand-by Interconnect
FX2L Fixed Relay - Itinerant Interconnect
FX2S Fixed Relay - Stand-by
FX2T Fixed Relay - Temporary
FX3 Secondary Fixed (Tone Signalling)
FX3C Secondary Fixed - Interconnect
FX3I Secondary Fixed - Itinerant
FX3J Secondary Fixed - Temporary Interconnect
FX3K Secondary Fixed - Stand-by Interconnect
FX3L Secondary Fixed - Itinerant Interconnect
FX3S Secondary Fixed - Stand-by
FX3T Secondary Fixed - Temporary
FX5 Temporary Fixed
FXC Fixed - Interconnect
FXCO Central Office
FXCT Control
FXDI Dispatch
FXI Fixed - Itinerant
FXIO Inter-office
FXJ Fixed - Temporary Interconnect
FXK Fixed - Stand-by Interconnect
FXL Fixed - Itinerant Interconnect
FXO Operational Fixed
FXOC Operational Fixed - Interconnect
FXOI Operational Fixed - Itinerant
FXOJ Operational Fixed - Temporary Interconnect
FXOK Operational Fixed - Stand-by Interconnect
FXOL Operational Fixed - Itinerant Interconnect
FXOS Operational Fixed - Stand-by
FXOT Operational Fixed - Temporary
FXRP Repeater
FXRX Fixed Relay
FXS Fixed - Stand-by
FXSB Fixed Subscriber
FXT Fixed - Temporary
FXTS Auxiliary Test
FXV CTS Exceeding 20'
FXW CTS Meeting 20'
FXY Interzone
FXYC Interzone - Interconnect
FXZ Zone
FXZC Zone - Interconnect
GCO GROUND COMMUNICATIONS OUTLET
LR Radiolocation Land
LRC Radiolocation Land - Interconnect
LRJ Radiolocation Land - Temporary Interconnect
LRK Radiolocation Land - Stand-by Interconnect
LRS Radiolocation Land - Stand-by
LRT Radiolocation Land - Temporary
M08C Centralized Trunk Mobile - Interconnect
MFL AERONAUTICAL MULTICOM
MFL1 AERONAUTICAL MULTICOM (MOBILE)
MFL2 AERONAUTICAL MULTICOM (TEMPORARY)
MFX MARINE OPS FIXED
MFX2 MARINE OPS FIXED (TEMPORARY)
MLSB Mobile Subscriber
MO Mobile
MO3 Mobile/Vehicular Repeater
MO3C Mobile/Vehicular Repeater with Interconnect
MO3I Mobile/Vehicular Repeater - Itinerant
MO3J Mobile/Vehicular Repeater with Temporary Interconn
MO3K Mobile/Vehicular Repeater with Stand-by Interconne
MO3L Mobile/Vehicular Repeater with Itinerant Interconn
MO3S Stand-by Mobile/Vehicular Repeater
MO3T Temporary Mobile/Vehicular Repeater
MO5 Mobile & Temporary Fixed
MO6 Private Carrier Mobile Op (profit)
MO6C Private Carrier Mobile Op (profit) - Interconn
MO6I Private Carrier Mobile Op (profit) - Itinerant
MO6J Private Carrier Mobile Operation (profit) with Tem
MO6K Private Carrier Mobile Op (profit) - Stand-by
MO6L Private Carrier Mobile Operation (profit) with Iti
MO6S Private Carrier Mobile Op (profit) - Stand-by
MO6T Temporary Private Carrier Mobile Operation (profit
MO7 Private Carrier Mobile Op (non-profit)
MO7C Private Carrier Mobile Op (non-profit) - Inter
MO7I Private Carrier Mobile Op (non-profit) - Itine
MO7J Private Carrier Mobile Operation (non-profit) with
MO7K Private Carrier Mobile Op (non-profit) - Stand
MO7L Private Carrier Mobile Operation (non-profit) with
MO7S Private Carrier Mobile Op (non-profit) - Stand
MO7T Temporary Private Carrier Mobile Operation (non-pr
MO8 Centralized Trunk Mobile
MO8C Centralized Trunk Mobile - Interconnect
MOC Mobile - Interconnect
MOI Mobile - Itinerant
MOJ Mobile with Temporary Interconnect
MOK Mobile with Stand-by Interconnect
MOL Mobile with Itinerant Interconnect
MOS Mobile - Stand-by
MOT Temporary Mobile
MOU1 AERONAUTICAL UTILITY MOBILE
MR Radiolocation Mobile
MRT MARINE RECEIVER TEST
MRT2 MARINE RECEIVER TEST (TEMPORARY)
MSC SHORE RADAR TEST
MSC2 SHORE RADAR TEST (TEMPORARY)
MSR SHORE RADIONAVIGATION
MSR2 SHORE RADIONAVIGATION (TEMPORARY)
RCO REMOTE COMMUNICATIONS OUTLET
RLA AERONAUTICAL MARKER BEACON
RLA1 AERONAUTICAL MARKER BEACON (MOBILE)
RLA2 AERONAUTICAL MARKER BEACON (TEMPORARY)
RLB AERONAUTICAL RADIO BEACON
RLB1 AERONAUTICAL RADIO BEACON (MOBILE)
RLB2 AERONAUTICAL RADIO BEACON (TEMPORARY)
RLC SHORE RADIOLOCATION TEST
RLC2 SHORE RADIOLOCATION TEST (TEMPORARY)
RLD RADAR/RADAR TEST
RLD1 RADAR/RADAR TEST (MOBILE)
RLD2 RADAR/RADAR TEST (TEMPORARY)
RLG GLIDE PATH (SLOPE)
RLG1 GLIDE PATH (SLOPE) (MOBILE)
RLG2 GLIDE PATH (SLOPE) (TEMPORARY)
RLL LOCALIZER
RLL1 LOCALIZER (MOBILE)
RLL2 LOCALIZER (TEMPORARY)
RLO OMNIDIRECTIONAL RADIO RANGE
RLO1 OMNIDIRECTIONAL RADIO RANGE (MOBILE)
RLO2 OMNIDIRECTIONAL RADIO RANGE (TEMPORARY)
RLR SHORE RADIOLOCATION/RACON
RLR2 SHORE RADIOLOCATION/RACON (TEMPORARY)
RLT RADIONAVIGATION LAND TEST
RLT1 RADIONAVIGATION LAND TEST (MOBILE)
RLT2 Radionavigation Land Test - Temporary
RNV RADIONAVIGATION LAND
RNV1 RADIONAVIGATION LAND (MOBILE)
RNV2 RADIONAVIGATION LAND (TEMPORARY)
RPC RAMP CONTROL
SAR SEARCH AND RESCUE
SAR1 SEARCH AND RESCUE (MOBILE)
WDX Radiolocation Weather Radar
WDXS Radiolocation Weather Radar - Standby
WDXT Radiolocation Weather Radar - Temporary
