PLMR System reception
JKRHawaii
Aloha! For those in Hawaii, particularly Honolulu, are you able to receive the PLMR system? This is formerly known as the PACMERS system for the military in Hawaii. I have a Uniden 436hp programmed using the RR database and with the latest firmware but am unable to receive anything? I was wondering if anyone local with a 436 HP has any advice on how to receive and listen to this system.
Thanks much for any assistance.
JKRHawaii
Sybex, is your scanner programmed using the database? I'm just trying to understand whether l'm doing something wrong or whether I have to change settings in my scanner.
Thanks much
Sybex7254
Florida
The scanner I have in Hawaii is a BCD996XT that was programmed using FreeScan imported directly from the RR DB.
Make you you have the Service Types enabled for the TRS..Law Talk, Military, etc. otherwise that may be what is causing your issues.
JKRHawaii
Sybex: thank you. My services are all checked. My info is straight out of the RR database.
I have no idea as to why I'm not hearing anything
Thanks,
Jason
JKRHawaii
So to follow up, Sybex's advice is good. I was able to monitor Pearl Harbor PD on the PLMR system. It seems like the reception only comes in near Pearl Harbor. I was not able to hear anything else. Not sure if this is a antenna issue. I'm using the stock antenna.
bcd396t_honolulu
I picked up schofield and pearl harbor law enforcement today 2/8/17 using a uniden bcd396t. I programmed it at least 4 years ago using freescan.
Sent from my SM-G900V using Tapatalk
JKRHawaii
@ BCD396T:
Are you able to pickup anything else? I used to hear transmissions from Hickam and Kaneohe with my Pro-96 when they were not rebanded. Now I sporadically hear Pearl Harbor and Schofield Police and nothing much else.
bcd396t_honolulu
I listened for 3 hours today, I heard schofield range control main, pearl police, kalaeloa police, schofield police, and various TGIDs: 1260, 3026, 238 (range), 170, 1383, 1199, 1398. They are all being picked up on the shafter sites. Make sure your TGIDs are set to "search" and not "scan". I made the mistake once and coul only here TGIDs I had saved.
MtnBiker2005
San Diego County, California
System 288 Pro96com Reports - (PLMR)
http://www.radioreference.com/apps/db/?sid=5674
__________________________________________________________________________________
-TowerInfo
System ID : 288
WACN : BEE00
Tower Number (Decimal): 1-17
Tower Number (Hex) : T0111
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Timestamp : Sun Mar 19 07:02:54 2017
SITE NAC: 283
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,406.10000,0.01250,9.00000,"Confirmed",0.01250,1
03,380.00000,0.01250,10.00000,"Confirmed",0.01250,1
04,406.10000,0.00625,9.00000,"Confirmed",0.01250,2
05,380.00000,0.00625,10.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"02-0004","v",406.15000,"02-0004",415.15000,0,6
"02-0027","c",406.43750,"02-0027",415.43750,0,0
"02-0036","v",406.55000,"02-0036",415.55000,0,5
"02-0075","a",407.03750,"02-0075",416.03750,0,0
"02-0099","v",407.33750,"02-0099",416.33750,0,5
"02-0123","d",407.63750,"02-0123",416.63750,0,0
"02-0137","v",407.81250,"02-0137",416.81250,1,6
"02-0162","v",408.12500,"02-0162",417.12500,1,6
"02-0186","v",408.42500,"02-0186",417.42500,1,6
"02-0204","v",408.65000,"02-0204",417.65000,0,5
"02-0243","v",409.13750,"02-0243",418.13750,1,6
-TowerInfo
System ID : 288
WACN : BEE00
Tower Number (Decimal): 1-21
Tower Number (Hex) : T0115
Flavor : Phase 2
Timestamp : Sun Mar 19 22:51:11 2017
SITE NAC: 281
-Tables
-Frequencies
"02-0051","vd",406.73750,"02-0051",415.73750,0,4
"02-0055","a",406.78750,"02-0055",415.78750,0,0
"02-0059","v",406.83750,"02-0059",415.83750,0,6
"02-0065","vd",406.91250,"02-0065",415.91250,0,4
"02-0078","vd",407.07500,"02-0078",416.07500,0,5
"02-0082","v",407.12500,"02-0082",416.12500,0,7
"02-0086","vd",407.17500,"02-0086",416.17500,1,4
"02-0091","vd",407.23750,"02-0091",416.23750,0,5
"02-0097","v",407.31250,"02-0097",416.31250,0,7
"02-0116","v",407.55000,"02-0116",416.55000,1,7
"02-0125","c",407.66250,"02-0125",416.66250,0,0
"02-0133","vd",407.76250,"02-0133",416.76250,0,5
"02-0150","vd",407.97500,"02-0150",416.97500,1,6
"02-0173","v",408.26250,"02-0173",417.26250,1,6
"02-0190","d",408.47500,"02-0190",417.47500,1,0
"02-0213","v",408.76250,"02-0213",417.76250,0,7
"02-0240","vd",409.10000,"02-0240",418.10000,0,6
"02-0261","v",409.36250,"02-0261",418.36250,0,6
"02-0277","vd",409.56250,"02-0277",418.56250,1,4
"02-0285","vd",409.66250,"02-0285",418.66250,1,6
"02-0293","vd",409.76250,"02-0293",418.76250,1,5
"02-0305","vd",409.91250,"02-0305",418.91250,1,5
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency
122,"T0116",288,"02-0001",406.11250
124,"T0118",288,"02-0011",406.23750
125,"T0119",288,"02-0029",406.46250
126,"T011A",288,"02-0021",406.36250
127,"T011B",288,"02-0021",406.36250
128,"T011C",288,"02-0149",407.96250
129,"T011D",288,"02-0357",410.56250
130,"T011E",288,"02-0053",406.76250
131,"T011F",288,"03-0511",386.38750
132,"T0120",288,"02-0005",406.16250
-TowerInfo
System ID : 288
WACN : BEE00
Tower Number (Decimal): 1-22
Tower Number (Hex) : T0116
Flavor : Phase 2
Timestamp : Sun Mar 19 21:31:58 2017
SITE NAC: 282
-Tables
-Frequencies
"02-0001","c",406.11250,"02-0001",415.11250,0,0
"02-0015","a",406.28750,"02-0015",415.28750,0,0
"02-0035","v",406.53750,"02-0035",415.53750,0,3
"02-0057","v",406.81250,"02-0057",415.81250,0,2
"02-0100","vd",407.35000,"02-0100",416.35000,0,1
"02-0129","vd",407.71250,"02-0129",416.71250,0,1
"02-0145","v",407.91250,"02-0145",416.91250,0,2
"02-0181","v",408.36250,"02-0181",417.36250,0,3
"02-0197","v",408.56250,"02-0197",417.56250,1,2
"02-0229","v",408.96250,"02-0229",0.00000,1,3
"02-0245","v",409.16250,"02-0245",418.16250,0,2
"02-0251","vd",409.23750,"02-0251",418.23750,0,1
-Neighbors
121,"T0115",288,"02-0125",407.66250
-TowerInfo
System ID : 288
WACN : BEE00
Tower Number (Decimal): 1-24
Tower Number (Hex) : T0118
Flavor : Phase 2
Timestamp : Tue Mar 21 20:05:11 2017
SITE NAC: 284
-Tables
-Frequencies
"02-0011","c",406.23750,"02-0011",415.23750,0,0
"02-0037","a",406.56250,"02-0037",415.56250,0,0
"02-0107","v",407.43750,"02-0107",416.43750,0,1
"02-0151","v",407.98750,"02-0151",0.00000,1,1
"02-0174","d",408.27500,"02-0174",0.00000,1,0
"02-0263","v",409.38750,"02-0263",418.38750,0,2
-Neighbors
-TowerInfo
System ID : 288
WACN : BEE00
Tower Number (Decimal): 1-25
Tower Number (Hex) : T0119
Flavor : Phase 2
Timestamp : Sun Mar 19 22:11:38 2017
SITE NAC: 285
-Tables
-Frequencies
"02-0029","c",406.46250,"02-0029",415.46250,0,0
"02-0064","a",406.90000,"02-0064",415.90000,0,0
"02-0101","vd",407.36250,"02-0101",416.36250,0,1
"02-0183","vd",408.38750,"02-0183",417.38750,0,1
"02-0221","vd",408.86250,"02-0221",417.86250,0,5
"02-0279","vd",409.58750,"02-0279",418.58750,1,3
"02-0320","vd",410.10000,"02-0320",419.10000,0,3
"02-0381","vd",410.86250,"02-0381",419.86250,1,3
-Neighbors
-TowerInfo
System ID : 288
WACN : BEE00
Tower Number (Decimal): 1-26
Tower Number (Hex) : T011A
Flavor : Phase 2
Timestamp : Tue Mar 21 18:36:55 2017
SITE NAC: 286
-Tables
-Frequencies
"02-0021","c",406.36250,"02-0021",415.36250,0,0
"02-0053","a",406.76250,"02-0053",415.76250,0,0
"02-0069","v",406.96250,"02-0069",415.96250,0,1
"02-0085","d",407.16250,"02-0085",416.16250,1,0
"02-0123","v",407.63750,"02-0123",416.63750,1,2
-Neighbors
-TowerInfo
System ID : 288
WACN : BEE00
Tower Number (Decimal): 1-27
Tower Number (Hex) : T011B
Flavor : Phase 2
Timestamp : Mon Mar 20 03:20:36 2017
SITE NAC: 287
-Tables
-Frequencies
"02-0069","a",406.96250,"02-0069",415.96250,0,0
-Neighbors
-TowerInfo
System ID : 288
WACN : BEE00
Tower Number (Decimal): 1-28
Tower Number (Hex) : T011C
Flavor : Phase 2
Timestamp : Tue Mar 21 18:39:21 2017
SITE NAC: 288
-Tables
-Frequencies
"02-0149","c",407.96250,"02-0149",416.96250,0,0
"02-0341","a",410.36250,"02-0341",419.36250,0,0
-Neighbors
-TowerInfo
System ID : 288
WACN : BEE00
Tower Number (Decimal): 1-29
Tower Number (Hex) : T011D
Flavor : Phase 2
Timestamp : Sat Mar 18 22:51:20 2017
SITE NAC: 280
-Tables
-Frequencies
"02-0325","a",410.16250,"02-0325",419.16250,0,0
"02-0357","c",410.56250,"02-0357",0.00000,1,0
-Neighbors
-TowerInfo
System ID : 288
WACN : BEE00
Tower Number (Decimal): 1-30
Tower Number (Hex) : T011E
Flavor : Phase 2
Timestamp : Mon Mar 20 03:16:43 2017
SITE NAC: 280
-Tables
-Frequencies
"02-0053","c",406.76250,"02-0053",415.76250,0,0
"02-0085","a",407.16250,"02-0085",416.16250,0,0
"02-0149","d",407.96250,"02-0149",416.96250,0,0
-Neighbors
-TowerInfo
System ID : 288
WACN : BEE00
Tower Number (Decimal): 1-31
Tower Number (Hex) : T011F
Flavor : Phase 2
Timestamp : Tue Mar 21 01:28:08 2017
NAC: 280
-Tables
-Frequencies
"03-0511","c",386.38750,"03-0511",396.38750,0,0
"03-0535","a",386.68750,"03-0535",396.68750,0,0
"03-0689","d",388.61250,"03-0689",398.61250,0,0
-Neighbors
Frequencies Usage Codes:
a - Alternate Control Channel
C - Control Channel
d - Data
i - System site FCC ID information
v - Voice
Talkgroups Logged:
25
127
164
166
169
170
179
180
185
225
230
289
1011
1023
1069
1089
1092
1094
1097
1197
1253
1303
1305
1329
1368
1397
1398
2061
2062
2099
3014
3026
3027
3029
3043
3052
4001
4021
RadioIDs Logged:
706
1003,1006,1031,1035,1036,1037,1038,1040,1046,1048,1049,
1698
2000
4531
5238,5256,5257,5264,5282,5341,5380,5384,5440,5445,5508
6806,6949
8007,8080,8300,8420,
24603
26366,26595
40023,40029,40079,40082,40083,40090,40092,
40103,40130,40146,40147,40148,40149,40152,40153,40154,40155,
40164,40167,40172,40177,40178,40180,40181,40191,40193,40195,40199,
40204,40207,40210,40217,40218,40221,40232,40233,40234,40235,40236,40237,40243,40245,40246,
40250,40251,40252,40255,40258,40262,
40317,40318,40322,40330,40334,40335,40338,40339,40341,40343,40344,40346,40349,40350,40351,40360,
40400,40417,40418,40495,40507,40530,
41176,41213,41236,41238,41240,41637,41640,41659,41677,
42247,42603,42742,
45021,45022,45059,45064,
45107,45109,45113,45115,45119,45128,45131,45132,45135,45141,45143,45149,45182,
45221,45224,45394,45520,45531,45538,45543,45558,45582,
45611,45615,45616,45618,45634,45646,45655,45660,45666,45667,45671,45673,45676,45681,45691,45697,
45707,45708,45714,45739,45753,45759,45770,45772,45773,45786,45789,45794,
45800,45809,45811,45813,45836,45851,45853,45858,45863,45864,45867,45871,45872,45874,45895,45896,
45906,45908,45941,45943,45946,45998,
46002,46539
47035,47178,47332,47688,47693,47695,47710,47713,47716,47746,
47906,47915,47916,47923,47930,47944,47945,47946,47948,47949,
47951,47954,47955,47996,
48083,48106,48107,
56065,56143,56239,56451,56454,56458,56528,56540,56542,56543,56553,56563,
56574,56577,56586,56599,56602,56603,56604,56614,56621,56624,56632,56635,56637,
57224,57237,57240,57241,
