Pls Help Stamford EDACS Program BC250D
pwscott
Chester County, PA
Hi- hoping someone can help me. I have a BC250d and ARC250Pro. I had Stamford's trunk system working fine but suddenly nogo. I live in New Canaan about a mile from Stamford line and signal seems fine, just can't get trunk settings right. Whether it's North system freqs or south or both in same bank, always in the order shown on ScanCT.com- I can't get the system to lock in ever.
Freqs as follows:
STAMFORD EDACS TRUNKING SYSTEM
by Tom Alessi, www.ScanCT.com
Channel Frequency South System
1 866.3875
2 866.6625
3 867.0875
4 867.3375
5 867.8125
6 868.0875
Channel Frequency North System
7 866.1125
8 866.7625
9 867.7875
10 868.3375
Set to EDACS WIDE, delay 2, Icall ON, AFS, Activity ID Checked
Freqs are all FM, Trunk ON, 12.5, 2 sec delay, PL Off, Lockout Off
Scanner works fine on CSP, Greenwich etc.
Please any help would be very much appreciated.
seamusg
Grand Blanc, MI
Freqs as follows:
1 866.3875
2 866.6625
3 867.0875
4 867.3375
5 867.8125
6 868.0875
7 866.1125
8 866.7625
9 867.7875
10 868.3375
You will have to put them in different banks
one bank
1 866.3875
2 866.6625
3 867.0875
4 867.3375
5 867.8125
6 868.0875
another bank
1 866.1125
2 866.7625
3 867.7875
4 868.3375
on an EDACS system channels must be put in the correct channel numbers in order to work
see this for the correct channel numbers:
http://www.radioreference.com/modules.php?name=TRSDB&sid=2024
the numbers in front of the freqs are the channel number to use
pwscott
Chester County, PA
Solved I think
Thanks, but I had them in the right order and in two banks- one north, one south. What I had somehow changed was ICALL from On to ONLY. Think I'm set, appreciate the response. I basicaly wnet and loaded a .mem file from last year and compared settings.
