Plymouth CMED new channels
matt131
I recently saw a new channel listing with a new PL tone for Plymouth CMED that is made up of narrow band channels. Does anyone know if these channels will be put into effect before Jan 1 2013? I assume it is safe to say that the old wide band channels won't be used anymore after 2013?
Any input is greatly appreciated.
ecps92
Taxachusetts
Since Narrowbanding is mandated by 2013, Yup.
All CMEDs [statewide] will add the new channels and Plym does change PL Tones
The change is adding the additional channels, but the old channels become NFM they don't go away. You can change them now to NFM and they will work
cmpsa
Is it confirmed that Plymouth CMED is now 100% narrowband mode now? No more wideband; they switched over?
Thank you
ecps92
Taxachusetts
No they are still FM, but changing it in our scanners won't make a difference in reception. :wink:
Thank you
cmpsa
Thanks guys...
The link Kenny posted, which has the CMED .pdf document seems to suggest they are still wideband mode to date plus ecps92 double-confirmed that too.
Southeast Massachusetts
CMED Freqs
All 7 CMED Centers in Mass will transition into narrow-band channels in mid to late 2012,although the specific primary and secondary channel plan is not definate at this point, it will be available as early as July in some areas in an attempt to phase it in seamlesly. DPH needs to ensure all EMS providers are aware of this and able to comply by having multi zone radios with each Regions channels and correct PL tones for operation Statewide. Hopes this helps, thanks SSB
