PM1500 Blowing Fuses
BlueDevil
WA
I have a Motorola PM1500 that is blowing the inline power fuse every time the power is connected to the radio. This started occurring after the truck that the radio is in was jump started. I am thinking that something was damaged within the radio causing the positive connection to go to ground when connected to the radio and therefore blowing the fuse. This is only occurring on the main radio unit. The remote head is powering up fine, although it goes into maintenance mode since it isn’t establishing a connection to the main radio.
Does anyone have any suggestion or ideas on what to check first? How about a service manual for the PM1500 VHF High Band High Power.
SNCZCA01DS0
There's usually a protection diode on the incoming power lead. It dumps everything to ground and will pop the fuse if it got hit with reverse polarity.
Would be an easy check. They are usually a large diode near where the power input leads attach to the circuit board. Likely you'll find a big scorch mark to assist in proper location/identification.
Usually replacing the diode fixes the issue.
RFI-EMI-GUY
There is generally a reverse polarity diode mounted right where power enters the radio. If the jump start was wrong polarity or excessive voltage the diode likely shorted. There could be more serious damage beyond that diode. I would locate that diode, remove it. Test the radio with a current limiting power supply. If the radio is OK replace the diode with new.
fineshot1
NJ USA (Republic of NJ)
Before jump starting a vehicle the main power cord should always be disconnected on any motorola radio.
The motorola radio cpu is always online waiting for the power button to be pushed to initiate powering up.
SNCZCA01DS0
Usually the diodes go catastrophically. Looks OK in the photo, but that doesn't mean it is. Make sure your power cables are good.
If you are not finding it and have ruled out the power up to the connection to the back of the radio, it's probably worth sending it in for repair.
nhfdcadet
New Hartford, Ct
I had one go in a vertex radio once and the radio started smoking, so you arent kidding there
com501
Astro25 radios are end of life, not supported at factory. A local repair shop if you are not good with electronics might be your best bet.
