Pm1500
njemt7212
NOVA
Hey guys ,
Having trouble finding the PM1500 pinout for the db-25 port. Anyone have it?
I am attempting to make an adapter for a fire-com intercom system in our rescue truck.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
njemt7212
NOVA
Update: I am now having trouble trying to interface the FireCom 3010 to the PM1500.
I have the speaker hooked up correctly to Pin 24 & 25, however i cant get the transmit and transmit audio
the following needs to be connected
PTT HI attempted pin1 which is labeled aux_ptt acording to the service manual and no dice
PTT reference
Tx Audio Hi
Tx Audio Lo
and the rx audio is connected to the speaker and operates correctly.
ramal121
Lots and lots of watts
Calif Whine Country
SteveC0625 sent you the pinout for the 26p connector on the control head. This would work except it sounds like you are going to the DB-25 on the radio chassis.
OK, receive is up on pins 24 & 25, good deal.
Connect TX audio high to pin 15 (AUX_MIC).
Connect PTT high to pin 1 (AUX_PTT).
Connect TX audio low to pin 11 and PTT reference to pin 18.
If this doesn't work, there are jumpers that will change the default function of the pins in case someone got inside. See attached for correct pinout and notes.
  • PM1500_100102.pdf
ramal121
Calif Whine Country
CRAP! Looking back I see a glitch.
On the PDF diagram, table 8-3 lists pin 15 as mic high. But on figure 8-5 the pin is labled monitor. Pin 12 is marked mic high. ??????
OK, I admit, I've never hooked a headset to a PM-1500 but there you go...
Let us know what you find out!
njemt7212
NOVA
thanks, I am going to attempt this tonight when I go in, I will definitely post a follow up
Ramal this is where I was getting confused last night where the two-tables aren't corresponding to each other. Motorola cant even keep it straight in the manual.
canthonysmith
Arkansas
Thank you but pin 13 is on the control head 26 pin connector. I was needing one on the DB-25 connector on the back of the radio itself.
canthonysmith
Arkansas
Yes, that is for the 26 pin chart for the accessory connector on the rear of the control head. I am needing it for the 25 pin connector (TIB) on the back of the main radio unit.
SteveC0625
I just did an internet search, and found the info on the radio's DB-25 in just a few seconds. It was also posted in July of 2011 based on the same question from the same OP as this thread but over on the batboard.
cmdrwill
So Cali
It IS in the service and installation manuals......
Two different type connectors.
Basic service manual 6871241L01-B
Detailed service manual 6871241L01-A
