pm1500
captk3
ponca city,ok
hello im a newbie to radio programming ive read every post, comment etc trying to figure this out and cannot. I have a motorola pm1500 that is brand new old stock i bought trying to program using astro spectra cps r 0500300 i think thats correct number at first i got the cant find specified file after many attempts finally got software to start and launch but now it communication failed with radio. ive tried from using hkn6184 cable to front and drawer unit from radio have tried usb to serial port from radio with and without RIB one time radio did say 1 CSQ on display but that was it. Ive read reread the readme file set uac to off , compality settings etc. Can anyone help guide me to what im doing wrong,
Thanks scott
KG4INW
Midlothian, VA
That's the wrong CPS. You need the Astro 25 Mobile CPS and the proper RIBless cable (USB or serial). That radio doesn't use a RIB at all. The USB cable I have here is part # HKN6148C but I'm not sure about the serial cable part number (could look it up if need be).
ETA: Mike beat me to it!
captk3
ponca city,ok
ok so I got my hands on a moto astro 25 rvn4185aa cps r11.00.00 and loaded on my computer but wont launch on vista platform its running windows 7 home premium , so now what the heck is going on need some serious advice,
thanks scott
KG4INW
Midlothian, VA
Perhaps you're missing some CPS files? Since it's safe to assume you didn't get that from MOL.
com501
BUY the correct software.
BUY the correct cable.
You have a $1500 radio. Why would you NOT buy legal software and get support you PAID for, and the latest and greatest features?
Mars_P25
Paid RR Supporter
Banned
The part number for current ASTRO 25 Mobile CPS R20.00.00 is RVN4185AV. Motorola's number is 1-800-814-0601. Give them a call and they should have you all setup by the end of next week, if you don't already have an account.
captk3
ponca city,ok
ok guys i got this radio programmed however im having problems figuring out the user selectable scan list i can press and hold scan and the buttons come up sel del rcl exit the sel del wont work they bonk at me the rcl and exit button work also i caint fogure out how to change between scan list i have 2 programmed. what am i missing ive read and re read help files ?? Any help . Ideas
Thanks scott
KG4INW
Midlothian, VA
In the Scan List window in CPS, do you have it set up for Operator Select? If it's set to Fixed, you'll get what you describe.
captk3
ponca city,ok
pm150
i belive so I don't have the auto scan enabled where exactly is that preference you are speaking of under the tree
KG4INW
Midlothian, VA
Scan -> Scan List (whichever one you want to be able to change from the CH) -> General tab of Scan List, near the bottom of that window, change Non-Priority Members from Fixed to Operator Select.
KG4INW
Midlothian, VA
I believe R17 was known to brick radios without warning, will need to double check that. Anyway, without looking at your codeplug, I'm not sure what's wrong. The info I gave earlier came from looking at a PM1500 codeplug I have here.
KG4INW
Midlothian, VA
The firmware needs to be upgraded since Operator Selectable scan wasn't enabled on PM1500s until Host and DSP R10.00.00. The radio currently has something older in it.
